Forscan question
MajsterkoV
Bartek
Poland
MME 21 Premium Iced Blue , MME 23 select Vapor Blue Me , Explorer ST 25
Is it possible to change language radio freq and all that stuff to Polish using forscan ?
rugedraw
Javier
Miami, FL
Auto Sales
Yes. You would need the country code for your country. You would need to change the first block in this line of the APIM to reflect the correct country code for Poland:
7D0-03-01
???? xxxx xxxx
And the TCU here:
754-10-10
???? xx
There are some other locations where the country code appears that may be relevant to what you are trying to accomplish:
720-04-02
???? xxxx
716-08-01
???? xx
I cannot guarantee this will properly provision everything in your car to work properly, but the first change I mentioned should at least change the APIM to what it should be there. If you do not know the country code for Poland, get the VIN of any Sync 4 Ford vehicle in Poland and I can get it for you.
MajsterkoV
MajsterkoV
Bartek
Poland
Found one on Polish marketplace
WF0TK3SU8NMA23163
edit. Found on some weird forum that 504C is Poland code. Is it right ?
rugedraw
Javier
Miami, FL
Auto Sales
WF0TK3SU8NMA23163
Seems that way. This is what that car shows and PTS shows it was built for Poland.
Ford Mustang Mach-E Forscan question 1725380965850-c
Ford Mustang Mach-E Forscan question 1725381023430-j0
Ford Mustang Mach-E Forscan question 1725381052814-gr
Ford Mustang Mach-E Forscan question 1725381075206-6v
Good luck. Lmk how it turns out. Remember to reboot each module in the wrench icon menu after you make each change.
MajsterkoV
MajsterkoV
Bartek
Poland
It works now i have to change other stuff to europe like radio freq etc
MajsterkoV
MajsterkoV
Bartek
Poland
So its in Polish i have change radio freq but it doesnt show radio station logos and voice command doesnt work. When i press button it shows commenad but it doesnt speak and u cant talk to car. Beside that rest is in Polish
MajsterkoV
MajsterkoV
Bartek
Poland
Update 1. So I have radi ostation logos and info etc but still voice control doesnt work
rugedraw
Javier
Miami, FL
Auto Sales
I don't know how many languages are programmed into these cars in terms of voice control functionality. Not sure if that can be made to work. If so, I don't know how to do it.
MajsterkoV
MajsterkoV
Bartek
Poland
So i have asked in Polish sync 4 groups there are some ppl that do that ~600usd for polish voices and maps plus 700 usd for ford pass
rugedraw
Javier
Miami, FL
Auto Sales
So perhaps it is cloud based. If that is the case, then paying Ford would be the only way.
MajsterkoV
MajsterkoV
Bartek
Poland
Ford prob will charge up to 2k usd . Poland...
EgiszZ
Egidijus
Europe
Ford Mustang Mach E 2022 Premium AWD
Hi,
Could you share what modifications you done to enable radio station logos?
I tried to change country code to 4C48 (Lithuania) in APIM and IPC, it added additional languages, but also messed up speedometer in Instrument panel (it shows MPH, and in big screen Car settings menu changed to "Show speed in MPH", which does nothing).
So I reverted back till I figure out what else has to be changed.
If you have notes of all changes, could you share ?
I trying to same thing, just in Lithuania , haha :)
Thx!
MajsterkoV
MajsterkoV
Bartek
Poland
Hi you have to check forscan spreadsheet , i have same problem still speedometer is in MPH and switching it in setting doesnt do a thing and after changing language i cant use voice commands. Write me on pv i will try to find those mods to enable logos and fm freq
EgiszZ
Egidijus
Europe
To switch speedometer to KMH (+ small mph), I reverted APIM country parameter back to US....
I'm fine with English menu, KMH speedometer is a must for me. Also menu changed saying Show speed in KMH (not Miles).
There should be something missing, I'll try to experiment a bit more. I have compared European MME As built to mine and there is lots of differences.
I managed to turn on European road sign recognition + round symbol. It only works partly, based on camera, since maps data is missing. So most of time it shows -- while driving in city.
Tried also fix maps, this seems a bit more tricky, on Sync4 ....
Only found instructions for Sync 3 with CyanLabs tool. For now it looks only way is
pay someone $$$ for this not really useful feature.
Also OTA + FordPass would be nice to have, but again, price European version TCU seems too high... I'll probably wait and see if prices will drop.
MajsterkoV
MajsterkoV
Bartek
Poland
Could you write me what to change to have road sign recognition and speedometer in kmh I have allready got a ticket first time driving on street :cwl: 50mph in 50kmh zone sooo...
