FP 5.0.1 missing start button
david_quick
Bremerton WA
2023 Mach E GT
So the FordPass update pushed yesterday completely removed the much maligned “Start” button. iOS version of the app. Now there is no capability to start charging immediately. Anyone else seeing this?
Edit. I had to go out , unplug and replug in the car before it showed up. Another question is this function BT or Cloud dependent? My garage is out of BT range.
ReverendPete
Pete
Denver, CO
2023 MME Premium, 2018 Toyota Highlander Hybrid
Software Developer
The button is there, for me at least, but only if the car is plugged in. It's on the home screen at the top right.
Ford Mustang Mach-E FP 5.0.1 missing start button IMG_0805
billy_at
Mach-E California Route 1
Weird, I've never had that button since the FordPass 5 upgrade. I only have the fan icon to turn on the climate control - is that the same?
david_quick
david_quick
Bremerton WA
2023 Mach E GT
No it allows you to immediately start charging. The name is unfortunate.
Snakebitten
Coastal Texas
2023.5 Mach-E
Have you checked for the button appearing once you plug into the charge port?
It's coded to not be present if nothing is plugged in.
billy_at
Ah I see. I thought it was for remote start, not starting a charge session. I'll see myself out then! :LOL:
AKgrampy
Fairbanks, Alaska
And if I understand correctly it is not to start charge session but to charge to 100%.
Lohugo
Oklahoma
2023 Mache E, 2022 F150 Lightning
The fan button is always there for me and I can start the AC with it.
tbrumleve
Tom
Oregon, USA
Shows on mine. Latest iOS app version.
Ford Mustang Mach-E FP 5.0.1 missing start button IMG_3309
Space_Pony
Indiana
2023 Premium Mach-E awdX
I hear all of the comments about remote starting and it sounds like climate control is not enough of what they want the car to do. What else do you want the car to do?
Maybe they want a remote start button along with a remote drive button to remotely drive the car to their front door.
I'm confused on why you need to remotely start a car that doesn't have an engine to warm up in the winter.
My MME doesn't have a start button, it has a stop button. I assume that's because it's setup to charge when plugged in. There's no reason to start it because it's already started.
Ford Mustang Mach-E FP 5.0.1 missing start button Screenshot_20240601_072747_FordPass
eStang
Larry
2021 Mustang Mach-E FE, 2021 Mustang Mach-E GT
software salesperson
The start button is for charging, and the fan button is for starting? What is for remote starting?
Starting climate is the same thing as remote starting.
AKgrampy
Fairbanks, Alaska
When you reach your programmed charge setting it will change to Start.
