Front Camera Fault & Pre-Collision Assist Not Available Errors
Seludip
Dipesh
Nj
2021 ford Mach-e
After paying , I don’t know if problem will be fixed. If problem still exist they will replace something else and charge more
kennethjk
Ken
MME Prem. EB 4WD, X3, IX50
I have this issue on and off. Went to dealer replaced ipma module and front camera. They billed 2800 Ford cover 1900 rest I have to pay. They have 8 year 60000 electric warranty. I don’t know, this is bs. Ford is always be fix or repair daily…
Isn’t it 8 year 100k or 80k miles
How many miles do you have on your car?
Your original sticker from Ford actually
Lists the warranty as I believe FordPass does also in addition to your web account with Ford
Check them out
Seludip
Dipesh
Nj
2021 ford Mach-e
Yes, 100000 miles. I have 49000 miles and problem started since they replace windshield. They said even though problem started during warranty period but problem still exist after warranty period. All repair made after warranty period , they cover partially. Also if the problem still does not fix. You have to pay for next part replacement if it is not replaced in replaced previously
Seludip
Dipesh
Nj
2021 ford Mach-e
The warranty period is 3 year/36000 milea
Seludip
Dipesh
Nj
2021 ford Mach-e
I don’t know how is Tesla reliability and warranty of electronics glitch but it seems to me better buy hybrid.
.... problem started since they replace windshield. ....
as did many others.
I am convinced that techs messing with the windshield running tools around the edges *probably* pull on the mini-coax cable pretty hard, and in some cases the resulting strain *may* create sketchy signal.
I'd say chances of fixing the problem simply by wiggling the connector, and rotating to relieve the strain, are just as good as replacing the camera.
Mirak
Kansas
JamesStew71
James
Jordan Ford
mustang mach e
auto tech
Hi there. This concern doesn’t sound like something we want you to experience with your Mach-E. Could you please send us a PM with your VIN and the name and location of your Ford dealer? I'd be happy to look into how I can assist you on my end.
3FMTK1RM4NMA13806 we have been getting this also. and the closest dealer to us sux balls. everytime we take one of our fords to them something is wrong with the service. front camera ans pre collision unavailable
try checking the connector yourself.....
- pop off the black cover (5 clips)
- rotate the coax cable/connector around to relieve strain
- pop cover back on
- clear codes either with ODB2, or hard-reset by disconnecting 12v fuse or battery for 15 minutes and re-connecting.
JamesStew71
James
Jordan Ford
mustang mach e
auto tech
3FMTK1RM4NMA13806 we have been getting this also. and the closest dealer to us sux balls. everytime we take one of our fords to them something is wrong with the service. front camera ans pre collision . Bluebonnet ford New Braunfels Tx
Ford Motor Company
Official Ford Account
Hi! I can take a closer look into these error messages and your concerns. Can you send us a direct message with your VIN and the dealership name/location?
dtc pulled
have you tried self-fix ?
- pop cover off front camera above rearview mirror. 5 clips
- rotate mini-coaxial cable around to relieve stress and sharp bend
- push in to make sure connection is seated
..... and .... clear DTC to see if you get another error.
