Front Drive Unit needs replaced
lindseybp
2022 Space White GT
Had the dreaded wrench appear last week. Dropped it off at the dealer last Friday. They just called me to tell me I need a new front drive unit. Won't have the part for two weeks and then another 1.5 - 2 weeks to do the actual work. So I may be without my car for almost a month. To top it all off they were out of loaners so I got a non-electric car from Hertz with 72k miles on it and it looks like it has twice that from the outside! :) Anyone able to explain what this is (front drive unit) and how significant of an issue this is? Is this more common than I think....just don't remember many of these issues popping up on the forum. Have had zero problems up until the dealer did the HVJ replacement a few weeks ago. Nothing like making a payment and not being able to drive it for a month. Thanks.
DevSecNetOps, General PITA
It's the front motor. Pretty big deal but a few GT's have had them fail and a handful of premiums as well. Ford doesn't seem to have spare motors sitting around so they have to shuffle to get one rolling for you. Sorry to hear, hopefully things brighten up soon.
AtomicInternet
SC
Focus RS, Mach E Premium
Ask if they can take out the front motor while they wait and give it back to you rear wheel drive. I know you can configure the car to be RWD, not sure how hard it would be to configure. I'm guessing they'll deny it simply because they'll have to put it on a lift, take out the motor, then put it back on the same lift in 2 weeks and put the new one in.
phidauex
Colorado
Renewable Energy Engineer
That wouldn't be possible - it is a whole different front axle assembly. The purpose behind the integrated drive module is that the motor, inverter and differential are all a single unit. With the motor removed, there would be nothing for the front axles to connect to.
Just Lurking
Paul
Washington
2022 Mach-E GT
Would you mind asking for and posting the invoice for what this repair would cost for someone out of warranty? I'm guessing many thousands but I'm curious whether it's closer e.g. to a $3-$4k repair or a $8-$10k repair. Good luck; hope they beat the estimates and get it back to you soon.
lindseybp
2022 Space White GT
will do
Doobster6
Len
Exton, PA
2024 Mach-E Premium extended battery, Vapor Blue
Retired manufacturing executive
I would be interested in knowing the failure rate for this issue among MMEs by year, and then the same for Tesla cars. Domestic companies suffer the well-earned reputation for forcing engineering compromises to save $1.00. On the other hand Munroe Consultants consistently praise Tesla as being the best engineered cars in their price range bar none. Musk supposedly shaves costs by deleting parts, not compromising them.
This is disappointing because there is an implicit promise that the simplicity of EVs, with fewer moving mechanical parts, would be trouble free for many tens of thousands of miles, and with lower maintenance too. This kind of failure, in under $20k miles, speaks poorly of Ford’s, or their supplier’s, efforts. Please share the specific details of the failure mode when they’re available.
keith
Butte ,montana
2021 mache e awd standard range
Equipment Superintendent MDT
My 21 select had front motor failure at 29k , the seal between the electronics failed and leaked all the oil out , my cost for the motor at the tome was $2100, warranty did cover it but it took 2 months to fix.i have 55 k on it now .I'm more carefully on inspecting it for leaks now
Ford Motor Company
Official Ford Account
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.
Hartland
Peter
Hampshire UK
2024 Mach-e AWD Extended
Civil Servant (retired)
I had a similar problem with a whine in my front motor on my 2021 AWD premium. The motor took a week to get from Germany to UK dealer & 2 days to fit however I only drove the car for 2 days as the dealer made me an very good offer to trade in for a new one 2024 same spec
ARK
Los Angeles
'21 Premium SR AWD
If I recall correctly, Munroe actually praised the front motor of the Mach-E. Tesla has had numerous major component failures over the years. Consumer Reports regularly trashes Tesla for reliability.
If you read a car forum, eventually you will see every issue under the sun crop up. It’s an issue of frequency and so far, a motor failure on a Mach-E remains a very rare thing.
