Google Maps & NACS Adapter
dtkindler
2023 Mach E Premium
Photographer
This morning Google Maps prompted me to specify which adapters I had available for use. I had added the NACS adapter on my phone but was still being warned about routing to Tesla Superchargers. Was relieved to see that the in-car Google Maps will finally, maybe, accept Superchargers as charging locations.
Charge_Rob
Dearborn, MI
2024 Ford F-150 Lightning (2025 Mustang Mach-E Rally on the way!)
Charging Nerd
Google Maps EV Routing for Android Auto has an adapter setting, but you need to set it in Android Auto, not in the Google Maps app itself. Google Maps EV Routing has routed to Tesla Superchargers since the feature was launched with Software Update 10.1.0, so if you're not seeing Superchargers in your routes I'd check that setting within Google Maps inside Android Auto.
Phobosbag
La
Mach e 2023 premium
Be careful, Google might suggest a Supercharger, but Superchargers do not accept non-Tesla EVs
Charge_Rob
Dearborn, MI
Charging Nerd
Ford vehicles have had access to compatible Tesla Superchargers since February 29 of last year. Google Maps EV Routing for Android Auto will filter out the incompatible Superchargers and route only to compatible ones.
Phobosbag
La
Mach e 2023 premium
Nope. Need double check via Tesla app.
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
The chargers that are not compatible with Ford, show incompatible in Google maps on Android Auto and it will not route to them automatically.
Ford Mustang Mach-E Google Maps & NACS Adapter 1000011526
Ford Mustang Mach-E Google Maps & NACS Adapter 1000011527
benk016
Tulsa, Oklahoma
FWIW I also got prompted yesterday to choose the adapter. I've had it selected in Google maps on my phone for a while but this was the first time it's given me the option to choose it on Android Auto.
Phobosbag
La
Mach e 2023 premium
I checked it. You are right.
Maybe it was fixed.
or it was my fault and I just searched 'supercharger' and go to incompatible one.
jdeve
Kentucky
2023 MME GT performance edition rapid red metallic
retired back to work IT guy
So which plugs and adapters do I check in google maps? J1772, CCS combo 1, Tesla (I have the Tesla adapter Ford sent me)
markw314
Sterling, VA
2023 Mach-E GT
How do you update for your adapter in Android auto? I can search for compatible chargers in Google maps, but Android auto will not route me to/via compatible Tesla chargers.
I see this, which does not let me choose NACS when connected to my car.
Ford Mustang Mach-E Google Maps & NACS Adapter Screenshot_20250117-112223
Steve Mathis
West Lafayette, IN
2024 Mustange Mach E Premium
Finance Manger
There are some Tesla walls (NACS) that dont convert. Be careful on those, Ill admit I added a (Tesla) app. To find Tesla Walls compatible. Ironically, the wall in my town is not compatible.
cheerioboy26
Matt
Pennsylvania
2023 Mach-E Premium AWD Ext.
Assuming that is Google Maps, your menu might be different than mine. From Maps, select your picture, scroll to Settings, then Your Vehicles, choose the three dots next to the Mach E and Edit Vehicle. I can toggle NACS there. You can also do it from the car, when navigating, select the search circle then charging, and then the filter button on the left of three that appears.
Guss-E 2021
Pierre
New Hampshire
2022 Mach-E Prem AWD ER
Compliance Specialist
I'm in my car now (parked don't worry). If you launch Google Maps via Android Auto and tap the settings cog, there is nowhere in the options to select you have a NACS adapter that I see. It is not under route options.
I too was recently prompted to indicate whether or not I have a NACS adapter just as maps opened. But I cannot, via the in car app, change that setting. Only in the app on my phone.
Ford Mustang Mach-E Google Maps & NACS Adapter 1000005921
cheerioboy26
Matt
Pennsylvania
You have to be navigating while in the car. From the box in the bottom left (with ETA etc) click the round circle.
Then you should see the attached, choose the left filter button, then in the next pop up (no photo) you can choose the plugs, which leads to the other photo you can toggle NACS
Ford Mustang Mach-E Google Maps & NACS Adapter PXL_20250117_200034212.MP
Ford Mustang Mach-E Google Maps & NACS Adapter PXL_20250117_200012560
