Heat doesn't turn on when slow charging?
raijinmach
Ottawa
n/a
I was sitting in my car while slow charging and had the heat on but it was only cold air coming out. Is this by design?
Was the car fully on or just in “Accessory”?
Start the car...
Just accessory, but the heat worked that way when fast charging
Don't use accessory mode, it will drain the 12V battery most of the time. The high voltage heater is also disabled in accessory mode (unless the battery is heating).
So the solution is to just turn the car fully ON and you'll have heat.
raijinmach
Ottawa
n/a
Ok thanks. Strange, I don't understand why EV's need to differentiate between 12V vs. full battery for this. It makes sense for ICE cars to preserve gas, but you're using electricity in both cases for an EV
shelnian
Ian
Seattle
2022 MME Premium AWD, 2023 Lightning XLT SR 312A
The 12v battery is 35AH and the high voltage is about a 100000AH battery. Heater is 5000 to 7500 watts and would drain the 12v battery in a matter of minutes.
E90alex
Seattle, WA
‘25 MME GT
Accessory mode is just a holdover from ICE vehicles as Ford EVs share a lot of computer modules with the gas cars.
There’s no point in using it on an EV other than for specific diagnostic procedures.
I’ve maintained that “Accessory” mode is unnecessary ever since I realized it existed on my car. Surprisingly, somebody on here wanted to debate me on it! 😀
TheRock
Canada
2024 Mach-E Premium AWD with Extended battery
+1 always forget to turn the car off when leaving and honks at me. Why honk. That's another discussion for another day.
AZBill
The heater does not run on 12V, it would have to be pulling over 400A. The heater runs off the high voltage battery. Only the fan motor is running on 12V.
