EVJoe
- Joe
- Mar 23, 2024
- Michigan
- 2023 Mach E Premium
- Engineer
'23 premium, Heated garage parked overnight, departure times always on in the winter. This morning on my way to work I had very little heat. This is also the first day this year that its been below 0F. I normally run the temp at 72-74 with the fan on 2-5, mix of defrost and floor. Today I left when departure time was ready. When I left the blower was on 5 and the heat button was on and I had defrost and floor selected. I ended up having to switch to all defrost almost immediately when I pulled on to the road as the windshield started fogging. A few miles in I turned the temp setting all the way to HI and also had to set the fan to 7 to keep the windshield from fogging. If I selected floor and defrost then the windshield would fog even with the blower on 7. I felt up near the defrost and it was blowing warm air but not hot air. It was cold enough that the rear side windows started to frost on the inside. We passed through a few areas where the temp got to -10F. at that point I had to but my hat back on and if I didnt have the heated steering wheel on I might have needed gloves. Are these cars just this bad in cold temps or do I have some other issue? I am almost positive that if I take it to the dealer that they wont find any issues as by the time I get there it wont be below 0 any more and it will probably blow heat just fine.
