How to deactivate Deep Sleep mode
kennethjk
Ken
MME Prem. EB 4WD, X3, IX50
Well it’s official, car is in deep sleep again and now with an alert, low battery
I've been away for two weeks.
hopefully car starts when I get home in two days
crazy that this should happen in only two weeks. Car was built in December and just got it two weeks ago.. drove it for 2 days and then had to go out of town.
zhackwyatt
I received this alert right before the car charged the LVB up (I could tell the LVB voltage using the widget).
kennethjk
Ken
All my worries are for naught. Got home after being away for two weeks and car started up no problem.
MACHEMIKE
Canada
2023 Mach E AWD Ext Range
Fire Fighter
2023 Mach E Premium Extended Range
**OBD READINGS JUST TAKEN IN SLEEP MODE**
My vehicle is brand new; only 6 weeks old. It has switched to Deep Sleep Mode for a fourth day in a row now and counting. Nothing has changed. I use Level II charging. My cars SOC is currently 38% and it switched to DSM after only sitting 2 hours. I never allow the vehicles SOC to drop too low nor do I charge past 90% ever. Not sure what the issue is. Disappointing.
Ford Mustang Mach-E How to deactivate Deep Sleep mode IMG_3942
Ford Mustang Mach-E How to deactivate Deep Sleep mode IMG_3939
Ford Mustang Mach-E How to deactivate Deep Sleep mode IMG_3941
Ford Mustang Mach-E How to deactivate Deep Sleep mode IMG_3937
Ford Mustang Mach-E How to deactivate Deep Sleep mode IMG_3936
What is your 12V quiescent average? That’s a parameter in there. 12V is at 71%, not low enough to trigger deep sleep unless the BMS isn’t getting a proper read on the SoC.
kennethjk
Ken
I used to get this after a day or two when I first got my car.
after a couple of weeks never have gotten it again
MACHEMIKE
Canada
Fire Fighter
I will check that… Ty
MACHEMIKE
Canada
Fire Fighter
Ford Mustang Mach-E How to deactivate Deep Sleep mode IMG_3938
You must be collecting data with the car off because the battery is draining with -11A. That alone will cause the 12V to drain and possibly go into deep sleep FYI (stop data collection when you're done and unplug the OBD device). The quiescent average of 54 mA is a little high, but nothing abnormal. 12V voltage and SoC seem normal. Therefore I think the following SSM applies to you:
https://www.macheforum.com/site/thr...e-deep-sleep-notifications-in-fordpass.26835/
MACHEMIKE
Canada
Fire Fighter
You are correct, the car was off when I collected the Donna. Also, I have been leaving my OBD plugged in but not connected to the Bluetooth on my phone that I am aware of. Do you think this could also possibly cause issue. I have unplug the OBD now, and put it back in its case.
Possibly, try leaving it unplugged for a night and see what happens. Unplug any Dashcams or the like too for the night to see if that helps.
