Lelandjn
Leland
Norman, OK
2021 Mustang Mach E 4x
I’ve had my MME since the end of May and successfully activated my Fordpass account including attaching a credit card. However, during my 6 weeks with the car I have never gotten the P&C to activate, only get a spinning circle for a couple minutes or more than a message stating to try again later. Keep waiting for it to work. Calls to Ford have not been helpful - they put me on hold to read FAQ’s, I’ve already done. I love the car as a third car for local trips but would not keep it as an only car because the owner experience with this and other Fordpass connection issues (including PAAK) has been bitter sweet to put it nicely.
William
William
Rochester, NY
2014 Ford Edge, 2021 Mach-E Premium
I will be using the Herkimer Denny's EA charger at the end of the month for a trip to Cooperstown so good to hear of your experience there and elsewhere. I believe EA and Ford have worked out the initial bugs for P&C.
Question for you or anybody. Do I have to set up an EA account before using P&C with the free Kwh or using the Ford app is fine until I use up the freebies?
I set up an account with EV before my trip out of an abundance of caution but it appears that FORD picked up the charge and put it against my 500 KWh in my FORDPass account. I got no charge from EV, just an e-mail from FORD telling me how many KWh I charged (57)and how much I have left in my FORD account (443).
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
Still waiting for Ford to activate P & C. Hope they get it done before we go on our first road trip in August!
Still shows pending activation on Ford.com. Called help line this morning and opened ticket. They told me that there should be a prompt displayed in the car to complete the process.
William
William
Rochester, NY
I set up an account with EV out of an abundance of caution but found that using the EV charger in Herkimer that Ford picked it up and just decremented my freebie 500 KWh the 53 KWh I put into the MME. It was Ford than sent me an e-mail confirming my actions and a later check on my EV account showed no charge against my credit card. Enjoy you trip. I hope your EV experience goes as well as mine.
stmache
Scott
Leesburg, FL
www.sthomasphotos.com
2023 Ford Mustang Mach-e GTP
Photographer
Me, too!!!
Ravensfan1996
Rick
2021 Mustang Mach E
I’m having the same issue, just spins then fails when trying to turn on the plug and charge
drivenfilms
2021 Mach E
Videography / Photographer
Easy! Thanks.
One thing you may want to add is that before the app recognizes the account, you need to VERIFY the account after you sign up. I went straight from signing up on the Ford website to the app...didn't bother checking my email.
ALSO I had to force quit the Ford Pass app on my phone and re-open it to do a "hard refresh".
MY21 J1 Premium RWD SR
Kabish
2021 Mach-E Mustang
Thanks for this post!
I heard about the 250kwh of free charging but the dealer had no idea. They just said "Well, it should just show up in your rewards eventually"
stmache
Scott
Leesburg, FL
Photographer
Did my first Plug & Charge at an EA station in Herkimer, NY. First plug on the station got a Charge Fault error from the car. I think that was me not inserting it correctly. The second plug on the station went perfectly. This was just a test as I was at 74% of SOC for this one so it didn't charge very fast (68Kwh) until it hit 80%. Used 11Kwh off my 250 while I eat breakfast at the Denny's the EA stations are next to.
RockwallRick
Lake Wales, Florida
I have got charge station faults every time at EA stations. Have not had a problem free plug and charge yet! I have a road trip coming up soon. I have already used 40kwh of my free charging pre testing for the upcoming road trip!
Rapid Ed
Ed
Bay Area, California
Prius
Does plug and charge work after your "free" charging without the annual subscription fee? Or do you have to buy that plan for it to work?
stmache
Scott
Leesburg, FL
Photographer
It will work via the FordPass if you have payment setup but at a higher rate.
Java
GA
MME Premium
For what it’s worth, I finally got this to work. My trek was much shorter than many here, but I feel your pain.
I set up my cc and then could never progress to activate the account. The activate button was always greyed out. No error notice or anything. Tried countless times. No joy.
Reading posts here, I went into my wallet to see if delete and re-adding the cc would work. I noticed that there was no “default card”. Odd since I only had one card for the account. I selected that one card as default. Then went back to activate and it worked (at least went through at “pending“). It took a couple of hours to process, but all looks good now.
Thanks to all for the advice and info!
Flomru
Artem
Austin, TX
Rapid Red Mustang Mach-E Select
I followed exactly the same steps, but I actually tried to add/remove cc without making it default at first and it didn't help either. Even if you add it right there on activation page. Making the card default is what allows to proceed with activation. Odd.
