How to Engage Autowipers?
horsiedad
North Atlanta
Ford Mach-E GT PE, Mach-E Premium
I've read through the owner's manual, and turned on rain sensing autowipers. But yet, when it starts to rain, they don't come on automatically. Do you have to have the wipers turned from the steering column on for this to work?
Astraea
MMe Premium AWD ER
You have to make sure the wiper lever is on the first tick up. It has a resting position that pulling, and holding it down you can control the wipers when you let go, it will go back to the resting position or off. Clicking the lever up once will engage rain sensing and they will only operate when enough rain or moisture covers the sensors.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Yep. Set the wiper stalk to what would otherwise be intermittent wipers. With rain sensing turned on, they will now do their thing. Also, the dial in the stalk will adjust the sensitivity of the rain sensing like it would otherwise adjust the frequency of the intermittent.
Mirak
Kansas
Anybody else have an issue with the rain sensing wipers being triggered without rain? It doesn’t happen often enough that it’s worth troubleshooting, but mine will suddenly trigger while driving under a blue sky. The weirdest one is 3 or 4 times now both the front and rear wipers have triggered, just once, when I start the car.
horsiedad
horsiedad
North Atlanta
No, but I'll have to be on the lookout for that behavior.
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
Mine has done it a few times. My other fords with the feature have never done that. It seems like even at its lowest sensitivity, its still too sensitive.
Badger_Prof
Randy
I have had it happen twice. Both times, there was a very heavy dust coating on the windshield. Maybe heavy dust looks like rain.
Mirak
Kansas
Apparently there is a way to set the sensitivity on the stalk. I’ll have to look at that.
Mirak
Kansas
After driving the car more, I think I may be closer to pinning down the bug of the auto wipers activating under clear conditions.
The car never activates the wipers when I start from being parked indoors. It has also only activated in error once or twice while driving (again, I’m talking clear conditions - not rain when the auto-activation would be expected).
Where the error almost always occurs is when I turn the car on after being parked outdoors for an hour or so. When I start the car, the front wipers will trigger first, followed by the rear wiper a few seconds later. One sweep only.
if it were dust or pollen or something you would think the same problem would occur while driving, but it generally doesn’t. There doesn’t appear to be any accumulation of dust on my windshield.
Excellent description for those of us who've never had this feature.
SpaceNeedle
Seattle, WA
Mach E
Yep, there are others in the same wiper-hell...
https://www.macheforum.com/site/threads/wiper-blades-randomly-wiping.4050/
