How to fisable car alarm
05reinvent
Steven
Newbury Park, CA
Mach E
With family sitting in car, I leave the car with PAAK close the door. Within a minute, the horn (alarm??) starts beeping and stops after 1 minute. How to prevent this from happening. I shutoff sensors but beeping persists.
hybrid2bev
Disable walk away locking. Or after walking away and the car locks, then use the FordPass app to unlock the car.
Crilly
Dale
Hartland, Wi
Why not leave the car on?
ARK
Los Angeles
Mustang Mach E
When you turn the car off, do you get a message pop up on the center screen saying “disable motion sensor? Yes/no” or something along those lines? If you hit yes the interior motion sensor will disable and the alarm will not sound due to movement inside the cabin.
Engijms
CA
Mach E AWD X on order
The turn off motion sensors only seems to work half the time. My poor dog who loves to go for a drive has an anxiety attack everytime I stop and go in a store. I love the car but the operating system glitches are annoying. Settings don't save.. tried turning off motion sensor thru screen but its back on next drive. I can't always toggle correctly between Andriod auto and sirius as another example. Am hopeful for an update at some point. Maybe I'm missing something.
shutterbug
Joseph
AZ
Grabber Blue FE
That doesn't do didly, and certainly not squat. I click yes, and the alarm still blares.
That setting has always worked for me, but I don't have many occasions to test it tbh. I think there's a setting to just turn the alarm off completely. Certainly not ideal if you want an alarm, but would help for rambunctious dogs.
My car is in the detail shop so I can't go look to see i f I misread or misremembered.
Tyldum
Norway
Mustang Mach E First Edition
Disabled in the settings. Got two profiles, and always toggle between the two when I go for a drive. That restores my settings.
But yeah, answering yes to disable the motion sensors when leaving the car doesn't work.
shutterbug
Joseph
AZ
Grabber Blue FE
Does the alarm go off if you press no? I've tried the setting that turns off the alarm completely, and it resets to alarm on the next time I'm in the car. Funny thing is that it only goes off when it's in my garage. So it's not as bad as those alarms from the '80 that would go off if someone just walked by.
gurugary
Gary
Idaho
Ford Mustang Mach E Premier AWD Ext range
I had the same problem, finally put a couple strips of scotch over the stupid sensors. Dog is happier now.l
Engijms
CA
Where are these sensors? I may do the same.
