Not on the default settings it doesn’t, my 2016 Camaro never did. I think it’s just weird. Like last people do not pay attention to it. Maybe more cars in the last 5 years have added it. But in most peoples cars I only see the fuel, not left over range. Again I understand this is cause it’s easier to fuel up in ice, I just wonder if we’ll get to to same point in EV.But they do. Your Crosstrek has an estimated range display (usually 13% optimistic), mine genrally gives a ~500 mile range when filled. It is just that the consequence of not paying attention can be mitigated by a 1-5 mile walk carrying a fuel can.
True because most people just intuit when they need to fill up. Again this is because of the prevalence and ease of gassing up. I’m curious when/if we will reach the same point in ev.Most modern cars do tell you range to empty, but it’s usually something you have to navigate to in order to see.
Also needs to say, please dont post on the forum or facebook what my range is so low…..Was going to post the same thing.
How about this: Add a sticker (suggested elsewhere so I can't take credit for it, however):
If by "intuit" you mean "read the gas gauge", then you are exactly right!True because most people just intuit when they need to fill up.
Correct, I mean intuit if they can make it to the next station or not.If by "intuit" you mean "read the gas gauge", then you are exactly right!
ThisOn my Bolt there is a bar on the left very prominently that at the bottom has your low end range and at the top your high end range and currently where you are trending in between those points. That is much more informative. With my Mach E the damned battery can't be trusted to even tell me how much is left. Park it and start it ten minutes later and suddenly it's 3 or 5% lower or 2% higher. It's become a bit of a laugh.
Not very much unlike an ICE vehicle, in actuality, in terms of how far you can go.At the end of the day, how far you can go in your EV based on a given battery charge level, has a lot to do with how you drive the car, along with temperature, and other driving conditions.
Yes, my daughter has a Leaf, and the GOM changes when you change the drive mode, take off e-pedal, climate control, etc.I think it would be more useful if it updated its guess in real-time. In winter, it assumes I’m going to use the heat. But sometimes I don’t. If I have the heat off, show me the range with the heat off. When I turn the heat on, drop the range to reflect that. A lot of EV and PHEV GOMs work that way.
I'm happy with the current 'guess-o-meter' function. But yes, it would be nice to provide a cheat-sheet for folks to easily see where the 'loss' of mileage was occurring. Perhaps Ford could add a screen option that would display the various components affecting the calculated available range, similar to what is provided following a trip.Anyone who has been on this forum for more than a week has encountered the question of "what happened to my range?!" and "why am I not getting xx miles?" and "I think I have the wrong battery".
For some people on this forum the Mach-E was their first BEV and others are hardened veterans. However by now many have had their cars for a few months with some celebrating a year. So clearly everyone is an expert and can answer the following:
How would you redesign the Guess-O-Meter? What would you change so that people aren't constantly asking these questions?
- Should it just display the EPA range at 100% no matter what? This obviously would lead to "what happened to my battery? It said I could go more miles!"
- Do all EV customers need to be given a math lesson before getting the car?
- Should there be no range displayed and only battery percentage?
What is your proposal to fix the problem?
