How To Replace Cabin Air Filter
Deleted member 19354
Guest
If it’s that simple and inexpensive I’ll be doing it at least once a year
Mustang Jedi
Jed
Atlanta, GA
2023 Mustang Mach E Premium
IT Consultant
Did you replace yours yet?
Excellent video and soooo simple. I ordered the filter suggested and did the job in less than ten minutes, including the time spent cleaning out my glovebox.
***WARNING***
the tabs holding the filter door are fragile and will easily break. Carefully move them away from filter door, do not use much force. The door is also being secured by the cable mentioned in the video.
dalola
SE Ohio
sunsetridgecabinhockinghills.com
24 Mach-E P4X, 24 Bronco Big Bend Sas, 22 Maverick Lariat FX4 4K, & Hot Rods
Retired 🇺🇸
IMO, this is a good application for a reusable filter, like a K&N. I find the filtering performance acceptable in this application, you can clean as often as you like, and will save you some $$ over the years. I have one in my Maverick, and will put one in the MME in about a year.
roamtheworld
Austin, TX
2025 Mach E Rally in Molten Magenta
Just replaced ours this week. Good cheap filters available on Amazon no reason not to replace annually.
Dave159
2023 Ca Rte 1, Equinox EV LT FWD
***WARNING***
Ditto on the door tabs, very fragile. I'm down to one:curse:
GreaseMonkey
Chicago, IL
24 Mach-E GT
Same. I think folks should report back when they DON’T break the damn tabs.
dbsb3233
TimCO
Colorado, USA
I just bought my 2nd on Amazon ($22, Pureflow Cabin Air Filter PC99542X). I'm replacing them every 2 years. Pretty easy to replace.
Mprunty
Matthew
Gardena, Ca
2024 Ford Mach-e Select
Onboarding Supervisor
I got some time before I need to replace my filter, but will definitely opt for once a year for the best performance possible.
