kamorela
- Kelly
- Nov 24, 2024
- Beaverton, Oregon
- 2024 Ford Mustang Mach-e Premium AWD ER
- Sr. Aerospace Quality Engineer, Retired
Well I finally got this message yesterday, oh joy:
Because I do have two "after market (sic) devices" I thought I should look into it.
But first, this:
(OK, better now.)
Aftermarket Device #1:
I have a hardwired dash cam, power for which comes from two fuse taps in the passenger foot-well fuse box. One - a switched tap - is for driving mode, i.e. vehicle power button is 'on' and the other - an unswitched tap - is for parking mode, i.e. vehicle power button is 'off'. Both circuits are integrated and controlled by an inline brain box that does two things: (1) it provides power to the camera when the vehicle is turned off (i.e. vehicle is 'parked'), and (2) it has a user-adjustable cut off function to prevent excessive battery drain when the unswitched 'parking' circuit is active. My cut-off is set at 12.4V. So then, when my vehicle is turned 'off' the unswitched parking circuit activates to provide vehicle-off camera power. So in parking mode, whether the camera is actively recording or not, it remains 'on'. To preclude unwanted video recording of the inside of my garage when I return home, or any other time I don't want or need parking mode recordings, I installed an inline kill switch to open the parking mode circuit (my unswitched circuit). My habit is to actuate the kill switch when I arrive home, but there have been times when I either forget or I clumsily don't actuate the switch when I think I have (it's a mini-push button style switch). In those instances, the 12.4V cut-off has worked as advertised to prevent battery drain and I've never had an issue with low voltage. Ever.
For clarity, my kill switch was actuated (power was off) in the time frame of receiving the 'Electrical System Drain' message.
Aftermarket Device #2:
I installed a Bluetooth (BT) 12V battery monitor so I could check my battery voltage at any time when I'm within BT range. At home, which is where I was when I received the message, I'm always withing BT range. Note: to check battery voltage BT must be activated in the monitor app. After checking battery voltage I always - ALWAYS - disconnect BT. I don't know if closing BT matters but in my own mind I'm removing a possible drain route. But because the monitor is hard-connected to the battery terminals, there could be some sort of static drainage I don't understand. (?)
Weirdness:
When I got the battery drain message I immediately checked my battery monitor app where I expected to see a horrifyingly low battery voltage, but instead it showed 14.3V and battery charging! My car was not plugged in to its wall charger, so WTH (What The Heck), how was my 12V battery being charged? Was there some update that tells the High Voltage Battery to take care of its little sister if it becomes anemic? Or what? I'm stumped.
Well in any event, after verifying the car would start, I was too tired to make sense of it all, so I plugged in my charger and went to bed, as any anxiety-prone person would do. This morning? -> all good. Chalking it up to X-Files weirdness.
But first, this:
(OK, better now.)
Weirdness:
