Increasiing mileage estimates?
dhcruz
1220 Running Springs CT
2023 Ford Mach e Select
I’ve noticed that after a year and a half of owning my Mach e Select, that the expected mileage per full charge has been increasing instead of decreasing.
In the first few months I was getting an expected driving distance of about 252 miles. I am now seeing an expected distance of almost 280 miles!
Could this be attributed to any of the software updates?
BTW, I charge to 80% and then add 20% based on the initial 80% numbers. For example : 233 @ 80% plus 20% x 233=46.6, so 100% = 279.6
If your MpK hasn’t changed, neither has your range. There’s a reason it’s called “GOM”.
And your math is wrong. 233 at 80% = 291 at 100%. (233/0.80)
dhcruz
How and where can I get the MpK?
Gloff
Sean
San Francisco
www.serramonteford.com
2024 F150 Lightning, 2023 Mach E Extended Range, 2007 Mini Cooper Cab,
Sales Manager
The GOM will recalibrate based on your driving history. If you're mostly in town/rural highways <50MPH, you're going to get more range than someone driving all 65+ highway, and the system will account for your averages.
It takes a while to break in your engine.
As your piston rings create friction in your cylinders after you bring it up to operating temps after multiple cycles, you’ll see a slight increase in compression and efficiency over time.
Either that or the computer is just guessing your estimated range. ?
AKgrampy
Fairbanks, Alaska
Where do you drive? If you do mostly city driving it would creep up. Of course as we move into winter it will begin to move down.
Phil-Springs
Phil
Colorado Springs
Hmm a thread guessing about how the guess o meter guesses.. how meta.
Ford hasn’t released enough data to know what the gom uses , the algorithm contains, the changes they’ve made over time , nor in real time what your car thinks to even try and calibrate it manually.
Suitsandty
Tyler
Kentucky
2021 Ford Mustang Mach-E Premium
Training and Recruiting Specialist
The other day I just thought it’s be “fun” to test out my GoM. We were driving at 70 mph on blue cruise. We went 10 MILES! With our GoM showing 0 miles and 0% with a 3.2 kw/h trip average… sooooo there’s that haha gave white knuckling a whole new definition
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
I think it does ~30 miles after 0.
Search for a test of it on YouTube
Pioneer74
Dearborn
2022 Lightning Lariat ER - 2025 Mach-E Premium ER
Give it a few more months. The GOM will start going the other way and you'll swear Ford installed the wrong battery.
Homestead
Oregun
23 Mach-E, F-350
Here is what my GOM has been reading after 100% charge since I got it last Nov. on a 2023.5 AWD w/LFP battery.
Has been going up as it warms up.
224 Nov 2023
212 Dec 2023
219 60F 1/28/24
214 2/19/24
216 40F 3/3/24
231 40F 3/9/24
230 52F 3/23/24
232 45F 4/6/24
251 51F 4/27/24
243 63F 5/18/24
248 78F 6/8/24
255 78F 6/22/24
252 68F 8/6/24
258 77F 8/17/24
275 83F 8/31/24
269 76F 9/14/24
Deleted member 19354
Guest
I am using premium Electric so should I be getting better results??
