iPhone 15 Pro Max and charging pad
MMENACE
Cory
Petaluma, CA
2023 Ford Mustang Mach E California Route 1 EAWD
Sounds great. Thanks for the response!
JeffGo
Washington, USA
2024 MME GT in Eruption Green
Does anyone get a charge from the Ford wireless charger? Mine has never give anything to my 13pro and now my 15pro. It has all the software updates, maybe it needs a warranty replacement. It does still warm up the phones - and this is not related to the iPhone 15 Pro overheating, which my phone doesn't seem to do.
circatee
Georgia, USA
Mustang Mach-E GT PU, 2025
It works for me. Alas, I don't use it; well, haven't needed to use it. I merely tried it when I first received my iPhone 15 Pro Max, to make sure it fit and such...
When you say it has all the software updates, do you mean you brought it to the dealer and had them install the WACM module update? That allowed my phone to stay charging longer, but did nothing for the heat.
JeffGo
Washington, USA
Yes, the dealer installed that update and nothing changed. Monday I had the phone on the charger for about 40 minutes and no change in charge.
Did you have CarPlay connected? If so, no change in charge percentage is actually normal. It charges at about the same rate that CarPlay runs it down.
sockmeister
Pennsylvania
2023 Mach-E GTPE
SW Engineer
5watt wireless. Hard pass except emergencies. Why car companies even sell these is questionable. My RX450H. $350 for this friggin 5 watt POS. "I don't want it" "Sorry it comes as part of the nav package..."
First thing I did in that car was turn it off. It would flash this orange LED the entire time, and constantly wake the phone. Which probably used more power than it could get from the charger.
Thankfully the MME is different. It just attempts to melt the phone instead.
Is it really just 5 watts? That explains a lot. I've got a Pixel 6 Pro and my complaints are pretty much the same.
5 watts, and 4 of them are converted directly to heat :D
It will charge the phone, but really slowly.
FordMachEGo
SoCal
2021 Premium AWDx April 2021 build.
I agree. Mine has always worked to keep about the same charge with CarPlay and CarPlay navigation active. Without it, he battery would quickly deplete. I have an older phone, an iPhone 11. It gets a little hot but AFAIK that’s normal with any induction charge.
JeffGo
Washington, USA
Yes, could be it. I always have CarPlay going.
Works fine for me (iPhone 15 Pro Max)
wmaney
wmaney
Wade
Mach-e GTPE, daughter drives Ford Focus Titanium
The TWRAPS charger replacement is totally worth it. I love it.
I ordered the TWRAPS - I believe the charge is limited to 7.5 W - I think this is Apple not allowing faster charging for 3rd party devices?
Art
Art
244SnowyGv932nFordC
Mustang Mach E
Retiref
For those of you that have a 2023 Mach e and a iPhone 15 Pro Max - does the Pro Max fit and charge on the charging pad?
Thanks for your help.
There must be more than fifty posts on the charging pad.
Why not use the USB to charge it. That will work with a phone protector that most people have. Apparently this wireless charge doesn't work well on many brands, so just ignore it. A phone protector makes it useless anyway.
wmaney
wmaney
Wade
Just FYI, my iPhone 15 Pro (not Max) has a Peel soft plastic case and it charges on the Mach e charge pad.
DevSecNetOps, General PITA
the USB port only supplied 15watts, the TWraps thing splits the power between 2 pucks. It's covered in it's thread(s)
