iPhone MagSafe compatibility?
No, the magnet just makes it easier to align the coil and holds it in place. But I don't think either of those will be an issue with the rubber mat.
Then I submit Occam's Razor is the correct approach instead of Frankenstein's.
That charging pad is plenty big and the rubber ridges will keep the phone in place.
agoldman
Charleston, SC
What is the charge strength of this charger? Is it at least 15w? If not the magnet thing is moot.
methorian
Roanoke, VA
IT Admin
I still think the biggest reason to want "MagSafe" in your Mach-E isn't by retro-ing magnets in, that isn't going to get you much (the pad should provide plenty of grip for the phone to stay put, and it looks like they have a rather large wireless mat under the pad, probably with a few coils for different phone positions).
You'll want a legit MagSafe wireless charger in there because it's currently the only wireless charger that will allow your iPhone 12 to charge up to 15W. All other wireless chargers will be limited to 7W charging. If you're using Wireless Apple Carplay and wirelessly charging on a normal Qi charger, you won't gain much battery life. Using a legit MagSafe charger will double the charging speed.
We'll have to wait and see how it actually plays out though. Just my .02 on the subject.
methorian
Roanoke, VA
IT Admin
https://www.ebay.com/itm/Wireless-C...-Max-11-XS-8-Cover-for-Mag-safe-/363202626673
For anyone still interested, here's some cheap magnet rings to put under that rubber pad that'll work great. $4. As for 15W idk if even the USB ports will do that, do we know?
We won't until someone nerdier can test. The built-in wireless charger would not charge an iPhone 12 at 15W since it isn't an official MagSafe charger. If you really wanted that wireless charging speed you'd more than likely need to get a 12V 20W charger that supports the PD profile the MagSafe charger requires for 15W charging.
1pt21Gigawatts
New York
2012 Toyota Camry
Architect
I really don't care about 15W wireless. The capability was announced in september for a December launch, i have no expectation of it being in the car.
My general thought is, "Does it charge wirelessly?" If so, I'm happy regardless of whether it charges my iPhone 12 Pro Max at maximum possible rate of not.
Your mileage will vary.
mattbostonmache
Matt
Newton, MA
Rav4
At least as of the iPhone X, 7.5W was ok if you weren't using navigation apps.
On long trips, if you use Waze/Google maps/etc, the battery will slowly drain faster than it can charge.
If you use the cars built-in nav, you'll be fine.
When I upgrade from my iPhone 11 pro to the 12, I will want magsafe to get the full 15W. I'll probably use an aftermarket mat.
eltonlin
NorCal
FE Gray
Using Apple Maps on the iPhone is more power efficient than google/Waze.
Good points.
Personally, I live on an island. A long trip is a trip that can be done with a BEV that has a real world range of under 230 miles at around 50 mph average.
As for Waze, I dislike it. It gives absurd directions and its traffic information is always wrong. Always. So, I'm set. ;)
Yes
You may be able to slip an aftermarket chargers under the passenger side mat.
malba2366
911 C2S
malba2366
911 C2S
That won’t be necessary. There are USB ports right in front of the charging pad.
Yeah but in most vehicles those ports only supply 5 watts, which is not enough to keep the phone charged while using maps and steaming audio.
