YeOldeTraveller
- Clark
- Jul 12, 2024
- Ann Arbor, MI, USA
- 2024 MME Rally
I use 1PD all the time, but regen in Whisper is less than I want, so I use Low to get that. This would be a non-issue if we could adjust ride, throttle mapping, and regen separately.The L was a carryover from the Escape/Bronco/Maverick line which use the same shifter knob (obviously the Mach-E doesn’t actually have a low gear). Rather than design a totally new part, they just decided to use the existing knob they had and added some regen so the L button wasn’t totally non-functional. Otherwise, it’s kind of pointless to have L on an EV that has a blended brake pedal and 1 pedal drive. If you want a lot of lift-off regen, you would just use 1PD.
Much better when sliding through a turn.
