Keeping Privacy Cover In?
imstriker
Matthew
Indianapolis
Tech
Has anyone figured out a trick to keep the floppy cover from popping out? Tape around the prongs seems to make it stay more often, but it still pops out one side about ever 5th time opening the hatch. I'm approaching the point of just ziptie-ing it in. I thought I'd see if anyone else had come up with something. Thanks!
machefan
NJ
I actually had the same issue on the loaner MME I had for a few days. My suggestion is to use a rubber band or a hair tie to secure it. Might also be able to gently squeeze the plastic holder together so it’s tighter.
DaMeatMan
Toronto, ON, Canada
I'm actually using small black rubber bands to hold it in place and it's worked pretty well so far, but a black hair tie would work just as well. It's annoying that the clips were made so flimsy that they pop out if you look at them to hard. ?
TheSteelRider
United States
'21 Premium RWD
There must be a quality control issue. Mine hasn't popped out, and the one time I took it out on purpose, I would describe it as difficult to remove it is so tightly held in.
DaMeatMan
Toronto, ON, Canada
I wonder if it's something they recognized fairly early and corrected down the line?
TheSteelRider
United States
'21 Premium RWD
Perhaps. My build date was Jan 9, 2021 when was yours?
At any rate my comment was really to say maybe you got a dud and you should at least open a case with your dealer.
Mine built Jan 16th. No issues with the cover popping out.
machefan
NJ
Doubt it, you can ask the dealer to replace them, not worth the 2 hour visit plus drive to the dealer in my opinion. Again trying to squeeze the clips with pliers might help.
imstriker
imstriker
Matthew
Indianapolis
Tech
Well, at least is not just me. The rubber bands are a great idea. That would be a little more removable. I have contacted my dealer but so far that seems to be getting the equivalent of a blank stare. I'm a Jan 24th build date.
Garbone
Gary
Loafer
I put Mine below the cargo floor. Very secure down there. No flopping issues.
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
I had something a little tall back there and when it closed it popped out. after that, it would pop out every time I opened and closed the hatch. I finally took it completely out, and re-installed it and its stayed in ever since. It seems you have to get it in just right for it to stay.
I don't think so. My build date was Nov 18th and my cover stays snapped in. When I first got the car I popped that out and then put those pins back but didn't "snap" them into place. I didn't realize I needed to do that and the cover would fall off after the lift gate was closed. I learned that I have to push those pins down into their sockets so they latch more positively.
Are you guys pushing those pins all the way down in there?
