- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
You probably need a new charge port. Have someone check if you have a charge coupler overheating code, if so, then get it replaced.I have been having issues for a while and noticed the issue in last year, but could have been even longer. After getting fed up with the slow charging, I finally had the dealer take a look in the last month. I was searching for people with this issue and thankfully discovered this thread and read the entire thing.
my situation:
2021 Job 1 Mach-E. Car starts charging at 8.4kW but quickly within minutes drops to 7, 6, 5 and eventually 4kW when charging on my 40 amp grizzl-e charger.
Tested another 2021 job 1 Mach-E on my home charger and it doesn’t experience the issue.
Tested my car on multiple chargers and am experiencing the issue.
I would also replace the J1772 cable at the same time, a bad cable with weak sockets can ruin a charge port.
