connoisseurr
- Connor
- Sep 29, 2021
- Northern VA
- 22 Rivian R1T, 23 Tesla MYP
- IT Engineering
Order guide is attached. I'll work on getting this post updated throughout the day.
LATEST 2023 MACH-E ORDER GUIDES:
2022 Mach-E FINAL ORDERS DUE: TBD
2023 Mach-E ORDER BANKS OPEN: TBD
2023 Mach-E SCHEDULING BEGINS: TBD
2023 Mach-E PRODUCTION START: TBD
NOTABLE CHANGES FOR 2023 MODELS:
SERIES/EQUIPMENT GROUP AVAILABILITY
PACKAGE CHANGES
2023 MUSTANG MACH-E ORDER COMBINATIONS
LATE AVAILABILITY – Subject to Change
2022 MSRP vs 2023 MSRP ADJUSTMENTS
- 5/9/23 ORDER GUIDE [PDF DOWNLOAD]
- 1/2/23 ORDER GUIDE [PDF DOWNLOAD]
- 8/25/22 ORDER GUIDE [PDF DOWNLOAD]
- Series Line Up:
- Select: 70kWh Usable Capacity Standard Range HighVoltage Battery (RWD or eAWD)
- California Route 1: 91kWh Usable Capacity Extended Range High-Voltage Battery (eAWD)
- Premium: 70kWh Usable Capacity Standard Range HighVoltage Battery or 91kWh Usable Capacity Extended Range High-Voltage Battery (RWD or eAWD)
- GT: 91kWh Usable Capacity Extended Range High-Voltage Battery (eAWD)
- For availability of the GT Performance Edition, please refer to the GT Series Equipment Group section
PACKAGE CHANGES
- New
- Mustang Nite Pony Package (55R) (Optional on Premium and GT Performance Edition)
- Deleted
- Ice White Appearance Package
- Comfort/Technology Package
- Mustang Mach-E Select RWD: 70kWh Usable Capacity Standard Range High-Voltage Battery
- Body Code: K1R
- Order Code:100A
- Mustang Mach-E Select eAWD: 70kWh Usable Capacity Standard Range High-Voltage Battery
- Body Code: K1S
- Order Code: 100A
- Mustang Mach-E California Route 1 eAWD: 91kWh Usable Capacity Extended Range High-Voltage Battery
- Body Code: K2S
- Order Code: 200A
- Mustang Mach-E Premium RWD: 70kWh Usable Capacity Standard Range High-Voltage Battery or 91kWh Usable Capacity Extended Range High-Voltage Battery
- Body Code: K3R
- Order Code: 300A
- Mustang Mach-E Premium eAWD: 70kWh Usable Capacity Standard Range High-Voltage Battery or 91kWh Usable Capacity Extended Range High-Voltage Battery
- Body Code: K3S
- Order Code: 300A
- Mustang Mach-E GT eAWD: 91kWh Usable Capacity Extended Range High-Voltage Battery
- Body Code: K4S
- Order Code: 400A
- Headlamps – LED Projector with LED Signature
