Lectron Vortex problem unlocking
aaaeeeo
WA
MME
I just received my Lectron Vortex today and tested it in a tesla charge center
No problem plug in, activate and charging at all.
But it took me more then an hour to figure out how to unlock the adapter from the NACS charger..
Basically the latch on the Lectron is now very tight and you have to press the latch really hard to have it released.
When you press it, you will immediately hear a click, but you need to keep pressing all the way down until you hear a second click to have it fully release.. Otherwise the charge will just stuck in between.
Since the latch is on the bottom side of the adapter, it's not easy to press that hard..
And this is not on any of their instructions..
Now I look close at the adapter and watched videos about their previous recall, I can see they changed the latch pin. It is now longer and going inwards 90 degrees to lock the charger.
On good side, I guess it is now very secure. Downside, they should update their instructions, it's no way intuitive to press that hard
StromSpeed
Marcus
www.stromspeed.com
2023 Mach-E Premium ER
Autonomous Vehicles
I have the new version of this Lectron adapter as well. Noticed you really have to press that underhand button hard to release the Tesla NACS. No stuck problems to date and have used it about 10 times/cycles so far.
I can see how the recall on this adapter was needed and the Tesla side must be firmly attached, given how much sideways torque happens at the charging station getting the Tesla cable to reach our cars.
More worried about that sideways load on the car side plug/port and if that will fail over time due to this sideload of stretching the cable to make charging work, plus the leverage the adapter also creates.
You are not parking close enough if you have a lot of sideways load. You have to get the nose up even with the Supercharging station. Don't pull the cables to reach, move the car up more.
Dhruval Shah
Dhruval
Winnipeg
I had to leave my Lectron adapter stuck to the supercharger yesterday. I just waited 3 months to receive it and went out to give it a try. I tried to press the release latch as hard as I could. I'm a 200lb and a fairly strong guy but nothing worked. Wasted my hour tried to get it unplugged but eventually had to leave it stuck to the supercharger.
Scott Libre
3rd Planet
2022 Dark Matter Grey Mach e
I am glad I read this post. I was getting ready to order one. At the current rate, I expect another year before I get my official adapter.
Jeff-NoVA
Northern VA
2022 Mustang Mach-E Premium
Did Lectron also manage the Chevy Blazer EV rollout?
Just order the A2Z. They just updated the design. The Lectron adapter has been problematic from the start.
Scott Libre
3rd Planet
A2Z, that is the brand name? Type?
Jlbern27
Socal
Mach e
Thats a magicdock now
Space_Pony
Indiana
2023 Premium Mach-E awdX
You forgot your sledgehammer?
4sallypat
Pat
www.kudo-ume-farms.com
Network Tech
Space_Pony
Indiana
