Lighted Pony Project (back it!)
RedDragon
22 Mach E AWD Premium Ext Bat - Rapid Red
Both the red and white need power. I think both were tied together and crimped in the diode on mine.
I just find it weird that it came this way. Is there a change is circuit board design or something that doesn't require both to be used? The pony lights up just fine without the red wire
New2EV
Jeff
Palm Bay Florida
Charger, Explorer, Chevelle, Mach E
Maybe. Mine was an early 4k model and it definitely needed both. Maybe later versions had a change to eliminate the white wire and John still had three wire harness to use up. If it lights up without the white, then go for it.
Jake Blues
Broken Arrow, OK
2021 Mach-E Premium ER RWD Space White
Hey, looking for some input. I installed the Pony I bought from a user here and sometimes after I shut my car off it will stay on for 10-20 minutes and other times it will stay on for an hour plus. I got home a little over an hour ago, and I just checked and it's still on. Any idea what's going on?
RedDragon
Did you opt for the always on wiring? If so, it stays on 15 mins after you turn off car and I believe it also stays in whenever the car is charging. Someone else can verify the latter statement.
Jake Blues
Broken Arrow, OK
Yes, I wired it for always on. Just checked and it's still on over 2 hours later, so I guess that means it will stay on while the car is charging. I'm a bit confused, though. Doesn't this draw from the 12v battery? Not sure why the lithium-ion battery charging would make it stay on.
RedDragon
For those of you who had the zener diode already installed on your pony when it came, were both the white wire and red wire tied into the diode? Mine new pony just looks like the white wire is tied into it. In the picture below you can see a tiny bit of the red wire peaking out of the grey sheathing. The white wire is fully connected to the diode.
Does this mean I don't need to attach the red wire to anything anymore? The white will just run to the firewall/bcm and the black to the headlight harness?
Just bumping this up. Did anyone else out there receive a pony with only one wire connected to the zener diode? This is cut in a way to suggest only a 2 wire installation, given the red wire is basically fully snipped down to the grey sheathing. Thanks.
Ghost Mach-E
Gil
Ford Mach-E Premium Awd -VW ID4 Pro s Awd
I tried 2 different versions of the lighted pony. 1 worked for 2 months before a piece fell off it. 2nd just died after 4 months. Just stopped lighting up. Im over it. Become a waste of time $$$. Proceed with caution
sgriffin130
Thompson Station, TN
'22 Red Mach E- C/T Pkg, '23 Escape PHEV/Prem Pkg
Dentist(retired)
Don't worry. As some of us have experienced, it will burn out eventually anyway(even with the diode installed) ;)
pdxzzr
Oregon
Grabber Blue Mach-E First Edition
Attorney
I bought an unused kit from another member here several months ago and installed it back in January, but couldn't get it to work at that time; exchanged a few emails with John, got busy with other things, and only now just finding some time to deal with this again to find the project was shut down. Which sucks a little bit. But I'm hopeful I can still get a little help here. This is my last shot at troubleshooting, otherwise I just take the hit of having an expensive and unnecessary front pony logo replacement ...
Does anyone happen to have copies of the installation instructions they can DM me? I want to go back and verify all the connections one more time. I have a version with the pre-installed Zener. I'm also quoting the posts below because:
(1) my kit has the red wire pre-connected to the Zener, not the white wire in the picture. Does anyone know if that really makes a difference?
(2) I also seem to recall reading installation instructions drafted at the beginning of the project indicating that both the red and white wires were connected to something. Does anyone else recall that or have information on this point? I've tested bypassing the Zener entirely because maybe my car's voltage is such that it doesn't require the Zener, but it didn't make a difference. Now wondering if there is something quirky that I will need to connect the white wire to something, but don't recall exactly what that was.
Cheers!
New2EV
Jeff
Palm Bay Florida
Cheers!
These instructions (see attached)
BTW...mine is no longer working. Haven't had time to troubleshoot it yet...but seems like these may not be made of high quality parts. Worked well for 6ish months.
pdxzzr
Oregon
Attorney
Thank you for the info and video - they were enlightening (pun intended)! it seems my unit came with the Zener installed on the wrong wire (red instead of white), and still needed to connect the red wire to the headlight. So got the pony light working, although it stays on for 5-10 minutes after I turn off the car. I guess now we’ll see how long it lasts.
Jim_In_Mass
Greater Boston
2021 Mach-E
SW Engineer
My lighted pony just died, likely within this week. It lasted about 8 months. What with the recent run of hot weather here in MA, I'm suspecting that there were just some parts in it which were not extended temperature range. Or that automotive extended temp range just isn't going to be sturdy enough.... But I'm a software guy, not a failure analysis engineer.....
I did enjoy seeing it glowing in the evening/night, but it really wasn't bright enough to see in daylight.
Now to figure out the next move. Leave this one in place, replace with a non-lighted one, or replace with another third-party lighted pony.
Tibot
Thibaud
France
Mach-e AWD
engineer
Anyone knows where I can find a lighted front emblem ? All suppliers I find seams on backorder...
thanks.
