Lighted Pony Project (back it!)
New2EV
Palm Bay Florida
Charger, Explorer, Chevelle, Mach E
Anyone knows where I can find a lighted front emblem ? All suppliers I find seams on backorder...
thanks.
I believe Ford put a stop to them. I don't think you'll find a retailer selling them. Maybe someone on here has one they haven't installed yet and would sell it to you....but most of those don't seem to last very long. Mine died within six months.
Yup. Very naive people marketed this.
Sundevil
AZ
Mach E
I haven't installed mine, would be willing to sell it but yeah as mentioned here they don't seem be very reliable
Reign of Ravens
https://ev-vida.store/products/mustang-mach-e-lighted-pony
It shows as "in stock soon," not "discontinued" - they say to email them if the stock is zero, so if I wanted to go for it, I'd email them to find out when the next restock will occur (assuming it will).
ValentinoRossi
21 Mach-e Premium AWD ER (10/21 build)
Got an email from kickstarter today saying Ford did a trademark dispute. Sure took them long enough!
Mine died when the summer heat came even with the diode like everyone else unfortunately.
Really liked it when it worked though (other than first batch issues like the tail not lighting up), hopefully someone from China will produce one since Ford is going to go after any domestic producers i guess.
Does this mean ev-vida is out? I believee they were selling the kickstarter one.
Trademark, sevicemark, and copyright holders are under a bit of pressure to enforce their rights to their ip. If they don’t, they can lose those rights. The fact that this was a small product and market is, unfortunately, pretty much irrelevant.
DJJeffT
Silver Spring MD
FE Grabber Blue (hers) & FE Carbonized Grey (his)
So I have 2 of these lighted pony's that I never installed. Been a crazy year and I am just not up to it. Was in the first and second legs of the Kickstarter project.
DM if interested.
New2EV
Palm Bay Florida
I really liked the light up pony on my 2021 premium. I mean…really, really liked it. So when I discovered it was no longer working, I was really, really disappointed. I ignored it for awhile, I checked the wiring to make sure it wasn’t an easy fix. But I knew…. ☹
Finally I decided I could do something about it. I’m an engineer (AE)….and I know enough about electronics to make myself dangerous. So maybe, just maybe if I was able to dissect the light up pony, I could fix it….. or even make it better.
My goals were 1) restore the light up feature 2) make it brighter 3) make it long lasting 4) make it repairable.
So I pulled my frunk out and removed the dead pony. I extracted the black inlay from the clear shell. It was surprisingly easy to do. Whatever adhesive was used was very brittle and yellow (probably epoxy). I was impressed with the plastics of the inlay and shell. Both withstood some manipulation without breaking or scratching.
Ford Mustang Mach-E Lighted Pony Project (back it!) PXL_20230806_154744789
Once the inlay was out, I pulled the circuit board and could see right away there were fried components. I believe they are diode arrays, but I’m not an EE and these parts were crispy. I also noticed what looked to be faint signs of moisture intrusion which didn’t surprise me as the adhesive wasn’t bonded all the way around the inlay. Also the board had no conformal coatings for environmental protection. I didn’t try to repair the board because it never was bright enough to begin with.
Ford Mustang Mach-E Lighted Pony Project (back it!) PXL_20230924_174426059
I used a free electronic APP called PROTO to lay out LEDs and determine what voltage they would require. I know MachE voltages can vary from 11.5 to 14.5. I wanted to keep the circuits lower than that so a buck converter could give me a nice steady output. I laid out LEDs in multiple configurations until I settled on 6 parallel strings of 3 LEDs each running on 8.8 volts.
I coated the inside of the black inlay with silver tape to increase the amount of light bouncing around inside the pony and began laying out LEDs in various configurations. Once I had what I thought was a good, uniformly lit pony, I marked the location and direction of each. I ordered supplies to turn my prototype into reality.
Ford Mustang Mach-E Lighted Pony Project (back it!) PXL_20230820_192411897
Ford Mustang Mach-E Lighted Pony Project (back it!) PXL_20230820_192405066
18x 2mm diffused round top LEDs, Clear heat shrink, 30 awg wire, clear UV resin, and clear silicone adhesive. Maybe $40 in supplies with plenty of spares left over.
Assembly took a long time, but I was careful at every step to make sure I was getting good solder joints and the light was reacting the way I wanted. I glued the inlay back into the clear shell with the silicone adhesive.
Ford Mustang Mach-E Lighted Pony Project (back it!) PXL_20230831_225955036
Ford Mustang Mach-E Lighted Pony Project (back it!) PXL_20230830_232035264
Once assembly was finished, I installed it in my car with the buck converter near the inside fuse box inside a 3d printed housing.
Ford Mustang Mach-E Lighted Pony Project (back it!) PXL_20230904_153531273
I think it looks great. Much brighter than before and much more uniformly lit. One of the posts on here noted they couldn’t see the reflection of their pony in the back of any car they were following. I can see this one. It’s not as bright as the running lights, but there is definitely a pony reflection in the middle when I pull up behind someone.
Ford Mustang Mach-E Lighted Pony Project (back it!) PXL_20230904_000035810
Ford Mustang Mach-E Lighted Pony Project (back it!) PXL_20230912_023102371
If a LED goes out, it should only dim one section of the pony and I think I can repair it on the car. If the buck converter goes out, it will be easy to replace. I’ve been running it for a little over 5 weeks and every time I see it I still think it looks awesome. I’ve been at highway speed and in blinding rain without any issues. Hopefully it’ll last a long time. If anyone else wants to attempt this project, I can provide information. Just be warned that it takes a lot of time to get it right.
Gullwingdmc
Chip
Boston, MA
If anyone wants to buy the one I have, DM me. It’s been sitting in a box since I got it from the kickstarter. I ended up upgrading to a GT so it came with its own illuminated pony and I forgot about this one.
itzbilly
New York
2022 Star White Premium ER AWD
Have one for sale in Brooklyn NY area for anyone interested.
GVicky
Stephen
Toronto
2021 Mustang Mach-e
I would definitely love this and I can’t imagine any MME owner not. Where can I see the initial design video?
nIceWhite
Premium AWD ER Ice White
I also have one for sale in New England. I have an Ice White so I never ended up replacing my white pony with a lit black one. Send me a message if interested.
