kindofblue
Reid
Arroyo Grande CA
Grabber Blue Mach e Premium 11/5/22, '25 Lexus 45h+ PHEV
I do not know why @Mach-E VLOG has not posted this, although they released a lot of videos recently about the 2023 California Route 1 they are reviewing. The video is great for showing atypical DCFC session with the Mach-E.
I usually recharge on road trips when I get down to 20%, so the sessions for my 2021 ER RWD Premium are shorter than shown (35 to 40 minutes).
Thanks. I too think 10-80% is more realistic than 0-100.
IgorKl
Pacifica, ca
'22 MME CaliRoute 1 AWD and '25 MME Premium RWD Ext
No. PG&E wipes my over-production every year. It’s the reason I bought a PHEV after my father died, so that I am using more of the electricity I am generating than I would have otherwise wasted as gasoline. PG&E keeps the electricity and all credits are returned to zero on true-up. I get to pay the delivery fee. ??
what plan you are? I was on TOU-C, right now TOU-D and they did send me checks couple first years.
Eric_C_Boston
Eric_C_Boston
Eric
North Shore, MA, USA
Retired Software Engineer
Massachusetts has split the generation and distribution. You can choose the company for generation so there is a range of rates.
0.2539 per kW for Generation
0.07764 per kW for Distribution
-0.00067 per kW for Transition
0.0405 per kW for Transmission
0.02198 per kW Energy Efficiency
0.0005 per kW Renewable Energy
0.0042 per kW Distributed Solar
0.00064 per kW Electric Vehicle
Total for me is 0.39869 per kW
GreaseMonkey
Chicago, IL
24 Mach-E GT
These are ridiculous prices! In Chicago the all in flat rate is around $0.13/ kWh and can be $0.02 more in the summer. I recently switched to the hourly market price and am ranging in the $0.08/ kWh, but summer will be more expensive. I live in an all electric condo and my winter consumption is 11x my summer. So all I care about is paying the lowest rate in winter.
GreaseMonkey
Chicago, IL
24 Mach-E GT
This was my 50%-80% SoC charging session on a EVGo 350 kW. 83.7 kW average at a cost of $0.167/ kWh.
Ford Mustang Mach-E Longest Range Mustang Mach-E Charging Test | 10-80% BB75893A-E1ED-4C23-9426-5437E9990A17
imstriker
Matthew
Indianapolis
Tech
The charging curve really is terrible. Rented a Model 3 from Hertz this weekend and what a great experience that was. Precondition, better efficency, and a decent curve makes a huge difference. The rest of the car kinda sucked though.
I do have to admit though that I opened the frunk multiple times from the screen. That was nice.
silverelan
Seattle
I will keep harping on this wherever I can, but @Ford Motor Company really, really needs to fix this lousy charging curve. I honestly don't see why they're not maintaining at least 90+kW deeper into the pack. That, and yes - PLEASE add charging details when plugged in. We aren't afraid numbers, I promise you @Ford Motor Company.
This is my version of @Jimrpa's frunk release ? (whose pain I also feel because I'm also a Job 1 owner).
the MME should definitely be charging faster than it does. 43 minutes to go 10-80% is just unacceptably slow, especially since the competition has improved their charging profiles by shaving minutes off the charge times. Polestar 2 and ID4 both had similar charge times as MME but have since had massive improvements to drop their times into the half hour range and now compete with Tesla. Hell, @Ford Motor Company just get us to 35 minutes and I’d be happy. Please toss in a detailed charging screen that displays kW too while you’re at it.
The one thing I like about the MME’s charging profile is that it’s pretty consistent regardless of the SoC when we plug in. It’s just that 20 minutes of max charging speeds isn’t enough to enable skip-stop charger hopping. Instead, it’s only enough to go about 80 miles to the next station vs 160 miles.
kltye
Chicago
IB MME Premium RWD
I hope I'm not hijacking this thread too much, but while we're on the subject: The battery heating strategy during charging also makes no sense. At high SoC, the battery can't charge very quickly anyway, but it insists on heating it up until the target of 98ish F. Then a minute later, battery cooling comes on, because of course it's not subzero outside. What a waste of energy (especially in places where you pay per kWh). Sure maybe it'll help if you're doing a roadtrip with multiple charging stops for the day, but isn't that what preconditioning is for?
It's almost as if the Ford BMS engineers had never seen a li-ion pack before, and they're just programming the logic to follow a spec sheet that you'd typically get if you're buying individual cells off ebay (aka not very detailed).
ANev
Anthony
Northern California
22 Premium awd
I’m worried that Ford doesn’t think the thermal management will hold up given the hvjb issues they’ve had. Obviously as a lower voltage car it’s not going to charge over 200kw but if they could hold the speeds around 130kw for the majority of the curve they would easily achieve that 30-35 minute 10-80% charge. I’ve seen a max charge speed of 164kw a few times when plugged into an ea 350kw post but I’d much rather just see a flatter curve deeper into the pack like the old e-trons.
SpaceEVDriver
Planetary Science
On our latest trip from Tucson to Flagstaff, we stopped in Payson and had to use one of the 350 kW chargers. We got 166 kW peak and averaged 111 kW over the 16 minutes we were plugged in.
Auto Motive
Doug
Valencia Pa
As https://driving.ca/reviews/comparison/2023-toyota-bz4x-vs-2022-hyundai-ioniq-5-ev-comparison says:
The bigger problem for Toyota is charging. Officially, it’s capable of 100-kilowatt charging, the lowest rating of any modern EV I’ve tested. Toyota’s official specs suggest it can recharge 80 per cent of its battery in an hour. In reality, it doesn’t even charge that fast. Do the numbers and that works out to an average charging speed of 58 kW. That’s not good. In other words, the Toyota is not a long-distance touring machine, its range too short and its recharging speed too slow for serious highway work.
Toyota shouldnt even be in on any conversations on ev adoption. It's like having a conversation with Joe "coal"Manchan.
