Low tire pressure warning don't disappear
PeBu
Petter
Norway
Mach-E RWD ExtendedRange
I got a low tire pressure warning.
I inflated the tire.
The numbers are now correct, and according to the compressor readings,
but every time I start the car I get a low tire pressure warning.
The low pressure tire, is now the high pressure tire, but it is still Orange.
It's like the "Error Flag" has not been reset.
Anyone else experienced this?
I have tried to look in the menus to see if I can reset the Warning, but has not found anything.
TheVirtualTim
Dearborn, MI
Usually if any warning message comes up on the driver info display you have to press the 'Ok' button on the steering wheel to dismiss the message.
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
Have you driven the car?
PeBu
Petter
Norway
I have driven the car "100 times", every time I push the OK button to dismiss the message.
The car work OK but its annoying to have to push the OK button to remove the message.
Pushrods&Capacitors
Round Rock, TX
Analyst
Ford Mustang Mach-E Low tire pressure warning don't disappear EF954B1C-BEC2-4959-BBE5-8563C200D53D
Perhaps you can go into the vehicle menu and do the TPMS re-learn procedure like any tire shop would do when rotating tires. Then use a TPMS tool like the one pictured to perform the re-learn. Not that you should have to do that but may be better than going to dealer.
breeves002
St. Louis, MO
2021 Mach-E GT PE
What do the tire pressures in the car say? Post a picture of the TPMS screen on the radio. Does it say "low tire pressure" or does it say "TPMS fault"?
You don't need to do TPMS relearn these auto learn.
PeBu
Petter
Norway
Here is the warning screen:
Ford Mustang Mach-E Low tire pressure warning don't disappear Bilde_2021-11-17_143447
It's Bar (metric) not PSI
"Dekktrykk lavt" means "Tire pressure low"
It is no fault indication of TPMS
There is no other info on the "big screen"
The car will soon go to the dealer for glass roof and window check, so can ask dealer then...,
Deuce399
Jan
Denmark
2023 Mach e GT-PE
Have the same issue, what was the solution to this???
DevSecNetOps, General PITA
Hmm, EU only issue?
Worst case try pulling the 12v negative for ~30 minutes. Excessive but I think it might force it. Unless you have a ODBII scan tool possibly.
For giggles, can you change just the bar to psi? (Not sure what the localization is for that, if it's the entire car changes to non-metric)
Fill all your tires to the correct pressure and drive the car several km to clear the warning. If the warning doesn’t clear, then you might have a bad sensor.
Deuce399
Jan
Denmark
2023 Mach e GT-PE
Great, Thx. will Go for a longer ride.
Rgds. Jan
Arjan
Arjan
NL
Ford Mustang Mach-E GT Performance
Same issue, have it for weeks now.
The difference isn't that big imho
Ford Mustang Mach-E Low tire pressure warning don't disappear tirepressur
I will keep ignoring it, but it still makes an annoying sound when i start the car.
3 bar is 43.5113213 PSI
Deuce399
Jan
Denmark
2023 Mach e GT-PE
Arjan
If you have had a pressure failure logged, remember to reset the fault in the menu on the screen in the car ?
Flo66france
Nallet
France
Mach e first blue grabber
Hello, I'm reviving this thread, I'm in the same situation... did you find a solution? I just drove 15km and the warning light is still on despite inflating the tires.
Sorry for the automatic translation.
Flo66france
Nallet
France
Finally, after two days with the light on, I deflated it to 1 bar and then reinflated it to 3 bar, then back down to 2.5 bar, and the light went out.
