Low Tire Pressure Warning
valeriol
Valerio
Jersey City
2021 Mustang Mach-E Premium RW
Sorry if this was already posted, I could not find it.
I used to get the warning as soon as one of the tires was more than a couple PSI below the recommended 39. I had not received one in a while so I checked and noticed that 3 tires were at 36 and one 35. Is there a way that I might have disabled the warning by mistake ? I can't find a place where you can turn it off and on. Or do I remember wrong and the warning comes on when the pressure is considerably lower than that ? The tires and rims are still the original ones and I have only 6K miles on them. I can make it a habit to check regularly, but I'd rather have the warning work.
Thanks,
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
20% low is typically the threshold. That puts them at about 31-32 psi, which is consistent with what I've seen reported on the forum.
valeriol
valeriol
Valerio
Jersey City
Thanks, I guess I remembered wrong or maybe the threshold is smaller at the beginning and then it adjusts.
I'll still just keep an eye on the gauge, just in case.
TPMS is not intended to take the place of a tire pressure gauge. As noted, the alert is not going to go off until you hit 31 pounds, which is 8 pounds or 20% below the desired cold pressure. Normal pressure loss, without any temperature change, is 1 to 3 PSI per month. Therefore, a great practice is to check your tire pressure monthly, and adjust to 39 PSI.
valeriol
valeriol
Valerio
Jersey City
TPMS is not intended to take the place of a tire pressure gauge. As noted, the alert is going to go off until you hit 31 pounds, which is 8 pounds or 20% below the desired cold pressure. Normal pressure loss, without any temperature change, is 1 to 3 PSI per month. Therefore, a great practice is to check your tire pressure monthly, and adjust to 39 PSI.
Yes, those are good things to keep in mind.
Thanks,
joebruin77
phil
LS400
TPMS often shows 29 or 30 psi on my front tires (cold). But it has never warned of low pressure.
Perhaps the threshold on my car is 30%...
Murse-In-Airy
Chaumont, NY
Mach-E ER AWD
Nurse
I definitely got a warning at 19 PSI this morning. And it wasn’t because it was 9° F in the garage. Though that did make plugging this more difficult.
Ford Mustang Mach-E Low Tire Pressure Warning EE67F8E5-DAB0-473C-89CA-59DBE17911AE
ReelSweet
Jody
Connecticut
Mustang Mach E
Ouch....at least you were in the garage at that temperature.
Benny’66
Plant Manager
Do you run your tires at that pressure?
phil
LS400
No. I fill my front tires to 33psi cold, to soften the ride. Weather doesn't vary much around here, but they can drop a pound or two on a cool evening. The rest is TPMS inaccuracy.
Benny’66
Plant Manager
Deleted member 25209
Guest
Thanks,
Hello I'm not sure where to make my first comment.
I have 2022 Mach E AWD GT.
Just had a warning tyre pressure is low.
The Ford 2022 manual states...tyre pressures When Cold should be 32 p.s.i.
I checked all tyres...all 30 p.s.i Cold.
Pumped them up to 32 p.s.i.
Car will be used in 3 days time.
So manual says 32 p.s.i.
Will check pressures again later
If it’s the same there as in the U.S., there is a sticker on the driver’s door jamb with the required pressure. It can vary with the tires (tyres) supplied on the car. 32 seems quite low.
Guest
I was wrong !!!
Manual was wrong !!!
Seen on drivers door column
Tyre 245/45 R20 103Y
Front wheels 1-3 people 39psi.
Rear wheels 1-3 people 38psi.
Question...all tyres were down to 30psi.
WHY...?
