SpaceEVDriver
- Aug 26, 2021
- Arizona
- Ground-based: CA Route 1 AWD, ER
- Planetary Science
Edmunds ran its 75mph range test with the Lucid Air Grand Touring and didn't quite reach the 516 mile EPA rated range. Clocking in "only" 425 to 438 miles on its two tests.
https://www.edmunds.com/car-news/te...ring-misses-epa-range-by-nearly-80-miles.html
Edmund's EV Range Test:
The roads
Edmunds drives on specific road routes that cover both highway and city driving around the greater Los Angeles area. We aim for a mix of 60% city driving and 40% highway, assuming that most electric vehicle owners will likely spend more time in stop-and-go traffic than they will on the open highway. Since no electric vehicle has exactly the same range, the route length is adapted to suit each vehicle.
The methodology
In EPA tests, a vehicle is run in the default settings at startup. If there are more efficient drive modes available, or if you can increase the level of regenerative braking, but the vehicle doesn't default to these settings, they won't be utilized. Edmunds' standard practice is to use the most efficient drive mode as long as it doesn't affect safety or practical comfort levels, such as deactivating the climate control system or significantly reducing power for accelerating or maintaining appropriate highway speeds.
We run with windows up and the climate control set to auto at 72 degrees, and we maximize regenerative braking during stops. We follow the posted speed limits and keep within 5 mph of them, traffic and conditions permitting.
