- Dan
- May 11, 2020
- santa fe,nm
- Website
- www.envirokarma.org
- MME (delivered 2/26/21), DIY eMiata BEV
- Solar Sales/install
not officially, and not directly via the charge port.Does anyone make a traction battery DC to 240 Volt AC inverter?
there is talk of bi-directional chargers, but nothing off-the-shelf I am aware of.
for up to 2000watt export, you can use the existing 12v "connection points", and use a simple cheap 12v->120vAC inverter.
However, if you are into a completely DIY r&d project... you *could* consider the following for up to 5000w export:
- locate the HV dc connector powering your dc-dc converter. this is the orange conduit pretty easy to see/access after you remove the rear "beauty cover."
- use positaps (or similar) to tap the HV power... and add mc-4 connectors and PV wire to a 600v solar charge controller. This line in the MME can provide up to 5000 watts of dc at 350-400 volts.... which is perfectly acceptable input to most modern hybrid Solar inverters. The MME would simply look like a 5kw solar array... as long as you can limit the current export in the inverter settings, all should be well.
