Blackpony
- Peter
- Sep 8, 2022
- Sherborn, MA
- Mustang Mach E GT
- Retired
Hi, as I have said before on this forum, I am new to all of this. I bought a 22 GT and love it but I didn’t look at charging in central New Hampshire. After buying it I did and realized that my distance from outside of Boston to Meredith is about 125 miles so round trip it is close to the listed range of 270 leaving little or no room for doing any driving up north. So I put in a JuiceBox 40 meeting the electrician who did the wiring and the fellow who is helping us finish our basement to set up the outdoor stand to mount the JuiceBox on. They met me and went to work and it was up and running in a few hours. I have had a problem setting up wifi however and I will work on that next time I am up there. Because it outside I am glad it has lock that will help deter it being stolen but I decided to trip the circuit breaker so no one can come and get a charge on me.
Now my question, is there any reason not to move the Juicebox between my NH house and my home in Mass? It plugs in and I have installed the 240 volt line to a receptacle in the garage where the GT is parked. I had planned on using the Ford charger here where the car will be most of the time. But realizing that the JuiceBox is also a plug in, I could do one of two things: use the Ford charger in NH and bring the JuiceBox to Mass and use that one here or move the JuiceBox between the two houses. The latter would likely require that I get a second mounting structure for the JuiceBox here which I assume should not be a big deal. I would keep the Ford unit in the car as backup or unexpected need.
So please let me know if this makes sense or if there are a reason or reasons for not doing this. Thank you if anyone can give me direction on this.
Best
Best
