UsernameChecksOut
Vancouver, BC
2010 Evo X, 2021 Mach-E GT PE
There was a parallel parking spot on a neighborhood street, and the only remaining spot for quite a ways. As I'm coming from a bit of a smaller car, I didn't quite trust myself to do without a bit of tenseness.
So I gave the self-park feature a shot. It worked flawlessly. The Mach-E did it in a single shot backing in and a small scoot forward. ? I'm definitely impressed.
I've just had to get used to the sequence of steps necessary for selecting the spot I want (press the Self-Park button, signal and drive forward to the sufficient distance past the target spot.) The Mustang also has a tendency to move too close to the car in front at the end of self-parking. I prefer scooting backward to be equally spaced between the front and back cars.
Ford Mustang Mach-E My Mach-E did this by itself today! (self-parking) 1
Ford Mustang Mach-E My Mach-E did this by itself today! (self-parking) 2
Meanwhile down the street... (they must not have been using Auto Pilot ?‍♂ )
Ford Mustang Mach-E My Mach-E did this by itself today! (self-parking) 3
OH2AZ2OH
Dublin, OH
Mach E 4X
Was it slow, or not too bad? I've parallel parked mine exactly once now. It had been years since I parallel parked a car, but it is quite easy in the MME. It has good visibility, a relatively small footprint, no large blind overhangs, and the camera is a huge help. I also might have gotten lucky. I was tempted to try the self parking, but I was on a fairly busy street and I only had a small window without a car in my lane.
UsernameChecksOut
UsernameChecksOut
Vancouver, BC
Actually, I felt quite fast! It certain backed in faster than I personally would have. For a brief moment I was worried that the front passenger-side corner would hit the car in front. But I guess the car's sensors know the actually distance. While holding the P button down, I was tempted to let go for fear of impact... but hung on and let it do its thing.
Having done the self-park just a few times now, I feel that the parts that feel slow are first identifying the appropriate parking spot for the Mach-E. Let's say there's a parallel parking spot on your right. You activate self-park and are creeping forward with your blinker on... and creeping and creeping. I ended up wondering "why isn't the car seeing this spot already?!". My observation thus far is that you actually need to creep forward further than you think before the Mach-E registers that spot as the one to go for. But once you do and shift into neutral and press down on the P button, things will go pretty quickly from there.
The other thing that I've found not to work very well is attempting parallel or perpendicular self-park where there's only one vehicle to park next to or behind/in-front of. My guess here is that the self-park feature was designed primarily to work with two reference points. So it needs a car on either side for perpendicular parking. It needs a car in front and in back for parallel parking. I could be wrong, but the few times I tried with only one adjacent car, it felt like the Mustang couldn't quite deal with it.
JerryL
Jerry
Philly
2019 Alfa Romeo Stelvio Ti Sport
Can you upload a video of the self park feature?
HowdyDoody
New England
Mach E Premium AWD Ext
I've used the self park dozens of times both in parallel and tight parking lot situations. It's one of the best features of the car. Always works flawlessly.
mpshizzle
Utah
Mustang Mach E 4X
I have used it quite a few times, and been pleased with it. Though I find the perpendicular park to be very slow.. not painful but close. Does a great job though!
I discovered a new behavior with perpendicular park today though.. I always assumed that it didn't look at painted lines and just used other cars as a reference, but I'm beginning to question that. Today it picked a spot where there were two cars with two open spaces in between.
Like this (∆ represents a car)
||_|_||
When it chose that spot I assumed it would just use the two cars as a reference and place it self right in the middle on top of the line. Instead, it picked a spot and stayed within the lines!
UsernameChecksOut
UsernameChecksOut
Vancouver, BC
||_|_||
Now I really want to go out and try this more to reverse engineer the logic/algorithm they use!
Are you certain that it read the lines? Or possibly it’s just trying to get to a fixed gap between itself and any one car it can identify? ?
mpshizzle
Utah
Mustang Mach E 4X
That's totally possible.. I'm not sure. I would assume it doesn't used a fixed distance, because you can't assume width of parking spots. But who knows!
Bigfeets
JM
