- Mark
- Feb 3, 2020
- Maryland
- 2021 GB E4X FE, 2022 F-150 Lightning Lariat ER
- Retired oceanographer
Yes.Okay great to know. Thank you so much. One more question, if you use your phone as a key and lets say your phone dies. Would the way to get in the car be using the door key code buttons and then the code you type in to start up on the screen?
Doesn't seem normal but maybe it is on the newer Mach Es. Those of us with early Mach Es can't open the frunk except via the manual pull behind the driver's side door.Is it normal for the front trunk to unlock when typing in the door key code also?
