Popping sound when turning?
zakth
Jai
2023 Mustang Mach-E GT eAWD ER
Sometimes, at low speeds, I can hear a popping/clicking noise when turning. The car has done this since I've had it and nothing has been called out for the shop while doing my inspections. This is my first EV so not sure if this is a normal thing to hear or now. Has anyone else experienced this?
Yep. The half shafts need to be replaced. This is a known problem with 2021 models, including mine.
Here is another thread that will give you more background, and an image of the SSM.
https://www.macheforum.com/site/threads/axle-clunk.5668/post-352035
I would print out the SSM and give it to your service adviser at the dealership when you drop off the car for diagnosis. It will make it much faster if they know the SSM. They confirmed mine in less than an hour and gave me back my car to drive until the parts came in.
Ford Motor Company
Official Ford Account
Hello, Jai! Send us a private message with your VIN and the name and location of your local Ford dealer. I’d be happy to see what I can do to assist with this noise concern. Thanks!
zakth
zakth
Jai
Finally got the car checked today and its the front CV Axel’s that need to be replaced. I’m not sure how long this part is meant to last but the car only had 28k miles on it.
If you are getting the half shafts replaced, it is a known issue. I had mine replaced as well.
zakth
zakth
Jai
Forgot to mention the stock tires are also in the red with even tread wear. I’m surprised that a 55k rated tire is already bad at 28k.
