Power Up 6.x Poll
Which Power Up 6.x are you on?
  • Total voters
    1,092
dr__bob
Bob
Murrieta, CA
2022 MME Premium AWD, 2016 Fusion Energi Titanium
Interesting sequence. I got DC-CHG4 a couple of days ago (overnight), and then on a trip today I got SVD-FX2 while driving. Is there any rhyme or reason on the order of these updates? Pick a card, any card? By now I've kind of lost track of which ones I've gotten and which ones I might still need. I did get 6.13.0, with no apparent ill effects. Still waiting, of course, for summer 202n, n>=3, for BC 1.x, x>0...
worachj
Eagan, Mn USA
2023 MME Select AWD Rapid Red Metallic (03/10/23)
24-PU0119-DC-CHG4 and then 24-PU1113-UNX-DC this morning.
2023 Select (MFD: 12/22):
06/15/23: 4.2.4
06/30/23: 4.2.5
06/30/23: Customer Satisfaction Program 21B36
07/13/23: 23-PU0314-DCM-LAT
07/15/23: 23-PU0105-DC-CHG2
09/25/23: PowerUp 5.1.1
10/18/23: PowerUp 6.1.0
11/06/23: PowerUp 6.2.0
11/06/23: 23-PU1103-NAT-VCE
12/08/23: PowerUp 6.3.0
12/14/23: PowerUp 6.7 **** INCOMPLETE ****
02/20/24: 23-PU0722-DC-CHG3
02/22/24: 24-PU0102-SVD-FX
03/08/24: 24-PU0119-DC-CHG4
03/08/24: 24-PU1113-UNX-DC
  • Like
Reactions: njb
mark0572
St. Louis, Missouri
2023 Mach e GT Performance Edition
Any way to tell which PU version I have? I have a 23 GT PE. Got the Tesla update yesterday and the UNX update today.
roamtheworld
Austin, TX
2025 Mach E Rally in Molten Magenta
Same here DC-CHG4 Monday and SVD-FX2 today. No rhyme or reason for our 2022 Premium. Just happy they are still happening.
shelnian
Ian
Seattle
2022 MME Premium AWD, 2023 Lightning XLT SR 312A
I stand corrected! I also confirmed with ChargePoint that it’s fine to run it at a lower charging current. But isn’t it generally true that a device might not be adequately protected (depending on its design) if it is on a circuit with a breaker that is too high (even assuming that the wiring of the circuit is correct for that breaker)?
Yes, it is very true that equipment has a maximum circuit rating because most equipment contains internal wiring and components that are also protected by the feeder breaker. The installation instructions for the Emporia EVSE I installed had this caution in bright yellow "CAUTION: To reduce the risk of fire, connect only to a circuit with 60A maximum branch circuit over current protection in accordance with the National Electrical Code, ANSI/NFPA 70, the Canadian Electrical Code, Part I, C22.1, and any local electrical codes."
Fixbear
Frank
ADK. foothills, NY
It seems that Ford periodically checks the car. Determines what you may need, and sends a update. Each vehicle is different because of so many variables. Dealer visits, build equipment versions, Trouble codes, and subscriptions/accessories. They are tailored for your car and it's needs. So don't expect you'll get the same thing as others. And with the numbers out there, they are staggered. Mine is a Oct 20 build. April 21 delivery date. So I've seen from 1.4 up.
silverelan
Seattle
I'm really curious as to what sorts of refinements these various updates are making. Is it all just background changes to allow smoother installation of 7.0.X or are these customer-facing changes to the car?
lanebk
Warrenton, MO
NQY 2022 Mach E Premium ER AWD
AH64LCT Test
I received 24-PU0102-SVD-FX2 today, too.
bigredx86
Pittsburgh, PA
2023 Ford Mach-E Premium STD AWD
Our ‘23 just got 24-PU0119-DC-CHG4, ❤.
Just Lurking
Paul
Washington
2022 Mach-E GT
My Job 2 '22 GT got SVD-FX2 this morning as well, one week since my last update (the DC-CHG4 update).
I'm still waiting to see the numbers start to go up for 24-PU0105-CMR-FX so I can my lane keeping fixed. Two people selected this for the poll a few weeks ago, and since then, no apparent movement.
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
Since the Tesla update was pushed to everyone regardless of past updates we should really report on this poll our last non Tesla update if that makes sense lol.
