Priority Update 22-PU0603-DC-CHG
Illinibird
Frankfort Illinois
I just got an OTA Update for DC charging; did anybody else receive this update? It took only 11 minutes to download and update the car. What exactly does the update do? The Power Up update says it "tweaked" the charging module to improve reliability and performance. Does this have something to do with the HVJB connector problem?
What does the text say? You should be able to capture the update text off your FordPass app.
Illinibird
Illinibird
Frankfort Illinois
Basically what I posted above. "Improved DC Fast Charging. We know how important DC Fast Charging is to you so we've tweaked the charging module to improve reliability and performance." I just wanted to know: 1.) Did anybody else receive this Power up OTA Update and 2). Is it related to the HVJB connector problem?
Mathington
Canada
Mach-E Premium SR AWD
Basically what I posted above. "Improved DC Fast Charging. We know how important DC Fast Charging is to you so we've tweaked the charging module to improve reliability and performance." I just wanted to know: 1. Did anybody else receive this Power up OTA Update and 2. I s it related to the HVJB connector problem?
I haven't seen anything. Are you in Early Access and did you have BlueCruise when you got your Mach-E or did you have to receive it via OTA?
Illinibird
Illinibird
Frankfort Illinois
Mathington
Canada
I'm really curious what this could be. Maybe there is a new charging curve update coming out that isn't part of any other update?
Did you have the 21P22 update already that gave you faster charging over 80% state of charge?
Illinibird
Illinibird
Frankfort Illinois
Yes to EA Program and no to Blue Cruise when I got the car 4-15-2021. Blue Cruise was added by the dealer when they did other updates.
Illinibird
Illinibird
Frankfort Illinois
I already have the 21P22 Update.
Mathington
Canada
that's even more exciting! I guess it's time for you to go out and DC fast charge to see if you get a better charge curve and then share with us :cool:
Illinibird
Illinibird
Frankfort Illinois
I hardly ever DC charge so it might be awhile. I'm just really curious if anybody else received this Power Up OTA Update and what exactly it is supposed to do.
Illinibird
Illinibird
Frankfort Illinois
Looks like this Priority OTA is two small files for the OBCC (Off Board Charger Controller) module.
I don't think it's related to the HVJB but that's just an educated guess.
Thank you for that bit of information. I sort of assumed with the DC charging causing the HVJB connectors to overheat this somehow changed how the battery DC fast charges.
Blue highway
Mach E Premium SR RWD
look forward to seeing what the charge curve changes are.
Mathington
Canada
What is the purpose of the OBCC? DC Fast Charging?
