Priority Update 22-PU0603-DC-CHG
Logal727
C
I’m curious what will happen for my car since I got this OBCC update at the dealer last month, does the OTA just skip?
ProximusAl
UK
Mach-E - SR-AWD - Star White
In my experience, you dont even get offered the OTA.
I keep my car updated with FDRS and think I've only ever had one or two OTAs back in the early days.
benk016
Ben
Tulsa, Oklahoma
2021 Mustang Mach-E GT
If your car got targeted for the OTA, and the dealer updated right before it got sent to the car, it will try and fail because it sees the versions it expected to be there are different and then It won't try again. Early on, the user would get a failure notice in fordpass, but this may have been resolved so you don't see a failure.
But since your car was updated last month, Ford's system knows you're already updated and won't even attempt to push to your car.
SOLIDAge
AJ
Austin, TX
Mach-E AWD Premium
This popped for me last night and man what timing. I’m currently driving halfway across the country to relocate and I noticed 3 things with this update after charging 4 times.
  1. The handshake at an EA station where I have plug and play enabled for my car went from 45-60 seconds to 5-10
  2. I haven’t had to put any pressure on the connection. With EA stations before I had to stand there and pull UP on the connection to support it while it was starting. I haven’t done that since the update and it hasn’t failed.
  3. It def seems to charge with a more consistent kw/h
ktn
Current: F150 Lightning SOLD: 2022 Mach-E Premium ER AWD
Just got this on mine. I'm in EA and have 3.5.4 installed.
ThatGuyLando
Iowa
22 CR1
Software Developer
Got this scheduled to install tonight, hopefully charging will be better moving forward. lots of handshaking issues with EA.
johnmark
JM
Massachusetts
'22 Mustang Mach-E GT
I guess we're on the same release schedule then and the same batch. ? I just got the update myself.
Ha same! Was just notified that it will install during the next update window - tonight at 2.
  • Like
Reactions: Bt3
DrJay32
Jason
Colorado
www.luminescentphoto.com
2022 Mach-E Select AWD
Photographer
I just got notified that this update is getting pushed to my car overnight tonight. Happy Halloween!
YouEeee
Duy
Anaheim , Ca
2022 ford mustang mach e gt
I got yesterday , just started my car today and ac í reset all back to default
Im seeing ac fan is weaker than before ?
Jonno21
Derby, UK
Mach-E AWD Long Range Space White
Just got it today in the U.K. No EA chargers here so will it make any difference? As far as I'm aware no EVGO public chargers here also. Oh well anything is better than silence. Only 6 months behind the U.S. :rolleyes:
