Questioning ABRP
Kennykustom
Ken
Canada
Premium awd lr
I'm very new to this car, and questioning these 2 anticipated charge times.
Is this accurate?
Ford Mustang Mach-E Questioning ABRP Screenshot_20220327-155003_ABRP
TRP
Mach E P4x, Ford F150
It should tell you the % of charge you have on arrival and % leaving the charge station. It minimizes charge time to make the total time of travel shorter.
Kennykustom
Ken
Canada
Premium awd lr
Questioning the 40 mins from 20-90%
ponydsp
'22 MME Premium 4ER, Taycan CT, 650s, F8 on order
Also make sure the consumption reference is the same as your current mi/kwh.
hybrid2bev
2026 Rally
Is this accurate?
If you have the updated charging curve, a warm battery and get full speed from a 150kW charger then those times on ABRP could be pretty close.
Patrick did 10% to 97% in about an hour.
Maybe, maybe not. Have you checked the speed of those chargers? They may be slow (low output) chargers.
Actually, that depends on the settings. Fewer stops will result in longer charging at each stop. There is a slider with Fewer stops on the left, Quickest arrival in the middle, and Shorter legs on the right.
  • Like
Reactions: TRP
RyZt
San Jose
Mach E4X
On consumption side, I have found ABRP to be too conservative. When I choose 2022 RWD ER, the consumption roughly matches my actual road trip consumption with my 2021 AWD ER.
On charging side, I have found it quite accurate up to 80%. After that it depends on your car’s software.
Kennykustom
Ken
Canada
Premium awd lr
In the limited time I have had the car.. I have seen 87kw from a 200kw dcfc. ( it was about -5c )
Thunderanger
Bruce
Lake Thunderhead
2021 Mustang Mach-E Select, 2019 Ram 1500
it’s better to go to only 80 because the charge time really slows down after that, you can set ABRP to charge to only 80 when it routes
Thanks for pointing this out. I think I messed up the KW per mile rate in mine. What's the default? Or is there one that is best for a Select with AWD and standard range battery?
Logal727
C
I think the default for the MME is what’s in the pic, I didn’t change that
Rocketman
TX
MY22 Premium RWD ER
