Range problems with the long range Mach e in the UK
Craig Thompson
Craig
Oxford, UK
Ford Mustang Mach e
Product Manager
I drive a 6 month old long range Mach e in the UK.
I am shocked by the lack of range.
I drive in a very careful and legally compliant manner and instead of the advertised range of 360 miles I recon that I get half of that, typically using 33 miles of range on my eleven miles commute....a mix of 20, 30, 40 and 60 mph roads.
I have contacted Ford and they state that the car is designed to work at 25degC (77 Fahrenheit). In the UK the average temperature never reaches 20degC even in the summer. The temperature in February typically is between 4degC and 10degC.
Have a bought the wrong car for the wrong country ? or is there something wrong with the car?
Thanks
Craig
RonTCat
Ron
Mach-E wannabuy
Did you buy this vehicle new?
hybrid2bev
2026 Rally
Nothing is wrong.
The WLTP calculation mandated for range estimates is terrible and only accurate if you drive like 35 mph.
Research WLTP vs. EPA range calculation methods.
https://insideevs.com/features/695492/epa-vs-wltp-ev-range-difference/
"WLTP is rather lenient, as the range specification is calculated just in the City cycle (at Low and Medium speed sub-cycles). This results in rather optimistic driving range numbers, as the vehicle is not subjected to high speeds in all-electric mode, as is the case with the EPA testing procedure."
Running the heater will reduce your range. Colder weather results in lower range.
evfinder
Noel
Van Nuys, CA
2022 Ford Mustang Mach-e
I always recommend that people use the US EPA mileage estimates as, while still a little optimistic, are much closer to reality than almost any other range estimate. For example for the OP's car the EPA range is 310 miles, 50 miles less than the WLTP range. Add to that the range loss due to winter weather conditions and range is going to be reduced by quite a bit over the WLTP range.
Most of the range loss in cold weather is because of the power needed for the heater. Using the seat warmers instead of the cabin heat can help there but the OP says he is doing an 11 mile commute so no need to be uncomfortable doing things to increase range.
Thanks
Craig
All EVs are impacted by temperature.
You misunderstood what Ford said. What they meant to say is that the OPTIMUM temperature for an EV is 77 degrees. Hotter, or cooler, than that impacts the battery.
MellowJohnny
Christian
YYZ
Solution Architect
Have you been pre-conditioning the battery prior to your journey? That will do two things - heat the cabin with shore power rather than battery, and warm the battery to allow for better range
Craig Thompson
Craig
Oxford, UK
Ford Mustang Mach e
Product Manager
Hi All, everything you say makes sense, thank you, ..........I am just disappointed with the real world range in a colder country.
Elektronik
Olegs
Latvia
Mach E RWD standard battery
UK is not the cold country :) all Scandinavia, Baltic countries are much colder than UK and use EV's without any problems.
Spacey
UK
Mustang Mach E
The Scandinavian countries appear to be well ahead in their charging infrastructure compared to the UK, (No surprise there) ? especially Norway so range in colder weather is not an issue.
See cold weather range tests from Bjorn Nyland on YouTube.
Unfortunately, all BEVs suffer range loss when exposed to cold temperatures. Some of the loss is due to a cold battery, and some is due to using the cabin heater. You can use less cabin heat if you need longer range. You can also precondition the cabin if you are plugged in prior to departure. That will help also.
By the way, all BEVs in the UK are required to be tested using the EU's WLTP test cycle. So do not blame Ford for failing to reach the WLTP range estimates. WLTP is very unrealistic, and it is a shame you were misled by the range numbers. Blame the EU government.
Geordietone
Scotland UK
Mustang MachE RWD Ext Range Dark Matter Grey
I have rather the same level of disappointment, have an ER RWD almost 2 years old, owned from new. At the minute in sunny Scotland (5 degrees C this morning), I have gone from the stated 369 to a massive 218 after a full overnight charge, the best I have ever had even in the Summer is 330.
Thunderbuck
Brett
Whitehorse, Yukon
2023 Mustang Mach-E Premium
IT Tech
Thanks
Craig
They call that range estimate a "guess-o-meter" for a reason.
The algorithm is constantly revising your range estimate. And a whole slew of things can make that range estimate a LOT shorter than it actually is. If you only have an 11 mile commute, and it's on a variety of roads, you are very likely getting an extreme worst-case estimate.
CTZ
Canada
2022 Mach-E
Your commute is 11 miles but you are worried about range? Can't you plug it in at night?
