Range question
Beachcats
Wally
Port Orange, FL
Mach e
For six months we have been quite happy with our MME 4X, PAAK performance not withstanding. We plug in every night and charge to 90%. Our range at 90% charge level has been in the 270 mile range. Suddenly, Sunday our range was 233 and has remained in that area since. Has anyone had this experience? Any ideas?
We were really pleased with what our range looked like until now.
jdsimard2012
Joseph
Montreal
Mach-E
What are you getting at 100%? Curious what others are reporting. For the past month I've been at 303 miles / 487 km.
hybrid2bev
2026 Rally
Mine did a similar thing last week, but I ignore the displayed range like others have posted.
https://www.macheforum.com/site/thr...ulate-how-far-your-mach-e-can-really-go.6104/
If you're miles per kWh usage rate has not changed in the past week then your actual range you can travel has not changed either.
RockwallRick
Lake Wales, Florida
22 Ford Maverick FX4
Ours dropped a little after doing a road trip but it still showed almost 300 miles after a 100% charge last week. Our actual range has been pretty close to the EPA estimate of 270 with a mixture of city and highway driving.
JohnnyForensic
VA, US
Digital Forensics
What everyone else said in this thread is spot on. Also, did you just happen to have a very spirited, high-speed, long drive before it dropped? It might have seen you zooming around as "well, I guess THIS is how they're driving now" and punished the GOM number to reflect the absolute fun you were having in your MME.
Road trips will do this, so will some updates via PowerUp or at a dealer if they reset the range data. Remember, this is just the guess-o-meter talking.
Beachcats
Wally
Port Orange, FL
Mach e
Thanks to everyone for the responses. Unfortunately, largely because of COVID-19, we only do local driving and we have not been "zooming around". We really look forward to some day trips and road trips. We were so happy with our earlier range figures which extrapolated to 300+ mile range on a full charge. We have not charged to 100%.
I already have a service appt tomorrow so I'll see what my dealer says.
Trede
Trede
Kent, WA
2021 Grabber Blue FE
Charging to 100% consistently is bad. Google lithium ion batteries. RTFM, it says only charge to 90% most of the time.
The Guess O' Meter is just that...just like on an ICE vehicle. If it says you have 30 mi of "gas" left, don't listen to it. Know that 10% of a 10 gallon tank is 1 gallon, and if you're currently only getting like 15mpg because you're going uphill, you're not making it 30 miles. If you have about 20kwh left in your battery, and you're currently getting 3.2 mi/kwh ... The GOM is just a tool to help you ESTIMATE things.
Last point...the phrase "Your mileage may vary"
Beachcats
Wally
Port Orange, FL
Mach e
I feel my dealer is trying. They do the updates that Ford tells them to do. They even made a second fob for me since PAAK doesn't work. Sadly, after their service, our PAAK still only works about 10% of the time. The diminished range? They just said it was within specs. We're monitoring and tracking the range data closely.
Olds442
Olds
Chicagoland
'21 GT, '22 Premium Ex AWD
sales
it's okay to charge to 100% if you have a big day and top off just before you leave. that last part is the key. but for every day "not gonna need the entire tank" going to 90 is fine.
some Li cork sniffers (i mean that in the best possible way) will only charge to 60 in fear their battery will lose capacity quicker. seems like fulgercarb to me, but to each their own.
but i was going to echo what @Trede posted about ICE cars. my car doesn't achieve near the rating, and never has. nor any other i've ever owned.
it's going to change based on how it's being driven, and those changes will arrive in bumps up or down. just use it as a gage and not an absolute.
stratigary
Mach-E AWD ER
Mine did the exact same thing 2 weeks ago. I plugged it in when I got home and charged to 90% before I went to bed and it said the range was about 275ish. Right before I went to bed my wife mentioned having to drive quite a bit tomorrow so I told the app to charge it to 100%. When she got in the car the next day the car was charged to 100% but only had a range of 255miles.
Since that time the range has been around 250 for 90% charge so I think its coming back slightly. As a note, I have updates set to happen early Saturday mornings and this range decrease happened Saturday night.
Beachcats
Wally
Port Orange, FL
Mach e
Mine is averaging in the mid to high 260s which I know they will say "within specs" but my concern is what happened after about five months of showing a range around 300 miles it dropped to about 250 and that was after a day when my charger light, which had always been blue, alternated frequently during the day between blue and orange. What happened that day...
timbop
The estimated range (guess-o-meter) is highly inaccurate and overly conservative, although colder weather does reduce battery efficiency - however a little cooler won't do much. It is meaningless that your GOM dropped the projected range; it is likely as a result of the GOM overcompensating for slightly cooler weather. Your car is not broken; it will go further than the GOM says.
Dylancch
Dylan
Swift current
Mach e
Construction
ith what our ra
233 is probably more realistic, as long as your percent per trip doesnt change than dont worry about it. im guessing the car updated mine changes from day to day, depending on weather.
