Rear wiper blade - longer replacement?
Hmm Trico 15-G little difficult to find. Any updated part numbers or options?
Go to your Ford dealer and get a Motorcraft one for a Ford Edge. See my post on the previous page for part numbers.
CarGuy11
Pittsburgh
2022 MachE4X Prem, 2020 GRSupra, 2016 Corvette Z51, 2024 Emira
Thanks but you said the tip of the blade isn't touching the glass when parked? I wouldn't like that. I hear the Trico one keeps contact with the glass.
Get the 14" one then, the end will still touch.
CarGuy11
Pittsburgh
scrb31
Larry
Seattle, WA
Mustang Mach-E GT, Mercedes GL450, VW GLI
Construction Operations Manager
I used a Bosch 15" and made a video of replacement. Amazon: https://amzn.to/3IhoOQr
This was stupid easy. I used the Trico 15-G. Got it next day from Amazon.
I did it one handed in maybe 10 seconds from start to finish with zero tools required.
Immediate improvement. Would recommend. 10 out of 10.
Tawna
Tawna
NH
23 Mach E premium
Am I just girl weak...I cannot get mine off. I have a longer one..
scrb31
Larry
Seattle, WA
Not sure. My 9 YO Daughter would not have had an issue with mine. I did it with my right hand, holding the new wiper with my left while on the phone holding phone to my shoulder with my head....
Afterwards I couldn't imagine someone struggling with it. There must be a decent amount of variance in manufacturing with the retaining clips.
Unless yours is somehow jammed, they shouldn’t take a lot of force to remove. Pull the blade subassembly away from the shaft. I used two paws, one holding the arm, the other holding the blade. Once the blade pops out of its detent, pull the blade toward the glass, away from the arm. ??
agdad
Derek
78155Ray
2020 Ford Edge
I just did a Bosch A 380 H change and it took less then 5 minutes
LOL I swapped my Trico 15-G in before I took my car on a test drive. The sales dude was like: “…” It took next to no time, certainly less than it took to get the blade out of its package. ??
Okuma
Nate
Atlanta
2022 Mach-E GT Grabber Blue "Blucifer"
Easiest improvement I've made to the car. I used a Bosch A380H 15". Removal and snapping the new one in took less than a minute.
worachj
Eagan, Mn USA
2023 MME Select AWD Rapid Red Metallic (03/10/23)
Pic of original clip. Pull to outside of car and then pop off.
Ford Mustang Mach-E Rear wiper blade - longer replacement? Wiper Cli
JRB100
Dallas
'22 Mustang Mach-e Select (C/T pkg) 10/10/22 build
Retired educator
Does the A380H stay attached since it does not have the same connector as the OEM?
