Removing trunk passenger side panel
MrLoganRoss
Seattle
Mach E
Hi.
I need to remove the side panel in the trunk of my ‘23 grow. I need to do this so that I can hit the reset button on the aftermarket dsp. Are there any good videos that show the tools or process?
GreaseMonkey
Chicago, IL
24 Mach-E GT
Say what?
iexiak
'23 Mach-e AWD
You are talking about beneath the C-pillar right? If so-
  1. Take floor out of car
  2. Take off the plastic piece on the bumper side that the floor rests on. There should be 2 visible bolts with the floor out and then 2 bolts that are under the cargo hooks - use a plastic pry tool to pop the cargo hook plastic bolt cover open. Unbolt all 4 bolts and this should come off fairly easily.
  3. You should now be able to work that side panel off. Use a plastic tool and go around the trunk lid gasket. Slide it around the piece until you find each snap-in and gently pop it out.
  4. Ford Mustang Mach-E Removing trunk passenger side panel 1741448844858-zt
  5. You can probably get to it now, but if not you would need to remove the upper portion of the rear seat. There is a cover near the seatbelt, take this cover off and then lift up on the seat. Be careful not to lose the foam washer thing.
  6. Ford Mustang Mach-E Removing trunk passenger side panel 1741448935308-eq
  7. Gently pry around the other side of this panel to unpop the clips holding it in place.
