Reprogramming Key Fob from another Mach-E
Worked fine for me.
Ok, will try.
Foot on brake or accessory mode is ok?
Follow the instructions. If they don't mention "foot", do nothing with foot.
bshaw
Boston, MA
I definitely wasn't doing it fast enough.
Once I sped up the operations, I saw the "Door code [xxxxxx]" as the 2nd FOB was recognized.
Then when I inserted the new FOB and pressed start one last time, it immediately said "Key Programming failed" in an orange popup on the IPC.
Its a 5x button F-150 FOB that I bought online, and I wanted to get the frunk button to operate.
0CO2
0CO2
Philomath, Oregon USA
MME FE
Academic
I tried everything suggested but it still doesn't work. How fast did you speed things to get it to program? I have a working frunk through Sync4 and the B-pillar key pad, but the F150 5 button fob with fresh battery doesn't program. Suggestions welcome. Thanks. thanks
jksu
LA
GT PE Shadow Black Night Pony
late or the game, but finally got the roof/window seal recall done on my 2021 job1 so also finally got all the module updates required for the remote frunk. tips here were super helpful, including the reminder about installing a C2450 battery into the new fob.
the f150 lightning fob programming took me 4-5 tries. probably because i didn’t wait the requisite 1 min between attempts and, maybe because tips here said to do it faster, the 1st few attempts i didn’t wait the full 5 seconds before swapping the keys. a youtube video which described the intervals by waiting for the 5 chimes to stop helped with the timing. after the 2nd key, i had a key code show up on the display to indicate i was on the right track. and at the end, indeed it says programmed key successfully.
love this forum! thanks again
AEtherScythe
Leon
Ford Mustang Mach-E, Ford Escape Hybrid
Sr. IT/Product Architect; Enterprise and Cloud Manageability Engineering
I’ve reviewed the procedure to program a third FOB when you have two original keys (procedure below). My question is what if the FOB is already programmed? The instructions say new unprogrammed fob. Can I follow this procedure to program an already programmed FOB?
Did you get an answer to your question?
I have two MME's, one with four keys (don't ask) and one with two.
I want to pair a key from the first MME to the second MME instead.
Above procedure did not work and I tried it very carefully numerous times.
Usually after inserting the two working keys re: steps 1-6, I get a message revealing the factory door keypad code, which I take to be a good sign.
But then the third FOB (programmed to other MME) does not actually get re-programmed to the new MME.
Any ideas?
bshaw
Boston, MA
If I recall, there is one last message that comes on the IPC after the factory door code is revealed. I think its something to the effect of "FOB programming failed" (or a success message).
Did you get either of those messages?
AEtherScythe
Leon
Neither success nor fail message after 2nd FOB showed factory door code.
I am thinking 3rd fob being already programmed to another car is the problem for me.
bshaw
Boston, MA
Reboot sync before trying one more time. That was my problem, and sync reboot fixed it.
MustangJim
James
Mustang MachE
How do you reboot synch. I have gotten the factory door code after the second key and the fob programming failure message after the third so I am hoping a sync reboot helps me as well.
SWO
MD, USA
You can use a previously programmed key, I've done it.
Bigger problem is that you need a dealer if you only have 1 key. Buy a 4th key and get that programmed.
bshaw
Boston, MA
I was getting a FOB programming failure on my 3rd FOB until I rebooted sync. It was not apparent from the error message that a reboot was required but afterwards, the programming was accepted on the first attempt.
Vol down and right arrow on the steering wheel until the center screen reboots.
ralteredstates
Guilford, CT
2023.5 Mach-E GTPE,(2021 gone), F-150, Corvette
I've tried to program one of the original fobs from my 21 so I could use it in my 23. Even replaced the battery. After 6+ tries, it still won't program. I followed the instructions exactly. Even turned the key on its head thinking that might help. Is there something else I can do to program the key before I go to the dealer? I must be missing something. Thanks
There are a couple of sets of instructions out there. One says to wait between keys for a few seconds, the other says to not wait. I failed when waiting but when I rapid-fired the keys it programmed just fine. ?‍♂?
ralteredstates
Guilford, CT
Thanks. Do you have the instructions for the rapid fire programming? Too many time frames. Do I still wait 5 seconds for each key? Or do I just push the start/stop button rapidly for each key and then immediately change keys? Confused.
