Resetting Guess-O-Meter
thx10
Missouri
2025 Mustang Mach E GT
Since picking up my ride in June, it has been all city driving. Would typically get the estimated range between 290-310 after charging to 90% (extended range GT - charging to 90 based on manual and battery type)
went on my first road trip and the efficiency dropped, as expected. So when I got home and recharged, it was approximately 50 miles less. I knew that might happen know it calculates based on previous driving, just like ICE fuel mileage estimators. Did a lot of city driving already and charged again last night. Thinking this morning it might have recalibrated after the charge, it didn’t. I did go into my car menu and reset the calculator (at the bottom of the General Menu and held it for a couple seconds). But the dash estimate didn’t reset.
Am I correct to assume that it will reset at next charging?
I know not to use the GOM and to do the math, but I would like it somewhat close
thanks for your advice
You want to reset EV Driving History.
thx10
thx10
Missouri
Yup. That is what I reset this morning. Couldn’t remember the exact title.
I assume it takes a while to recalibrate based on ”new” driving habits?
It resets to factory defaults. Then, you drive and it adjusts, over time, just like it did prior.
A-A-Ron
Aaron
DFW, TX
'21 MME Premium 4X
Since you’ve only had the car since summer, keep in mind that cold temperatures reduces range.
Yup, you're going to start seeing a noticeable difference in estimates now that the mornings are getting chilly. When the temps drop below 50, you'll see a pretty big drop from expectations. The car's not only looking at past performance but also current conditions
jav_eee
Javi
Edinburg, TX
2025 Mach-E Select
Energy Industry
it takes a while a while to be “accurate”.
