dhcruz
- Dan
- Apr 27, 2023
- 1220 Running Springs CT
- 2023 Ford Mach e Select
- Retired
Hi All,
I have a 2023 Mach e Select with standard battery. I get that it’s only an estimate but I recently saw a massive increase in estimated mileage. The estimate was reached when I charged the battery to 80% after driving around at a steady 40 MPH. At that level of charge the estimated mileage left was 231 miles.
If my math is correct its estimate is equal to 288 miles at 100% (231/80%=288). Is there another way to calculate?
Thanks in advance.
Thanks in advance.
All things being equal, the faster you go the more energy you use. From what I have seen the 250 miles estimated my 2024 standard range select is based on 3.5 mile per Kwh. If you look at the "This trip" it will show you what you are getting.
