Rusty doors
911roger
Roger
Nixa Missouri
Mach e gt
RN
I’ve checked my Gt 8 mo old there’s no rust the gt has huge rain gutters at the bottom of the doors A safe thing to do would be take a can of wd40 and using the long nozzle saturate the gutter. I’m surprised that the door isn’t aluminum
DennisD
Dennis
Omaha Nebraska
2022 Mustang Mach E
Driving School Instructor
I would guess that it is not aluminum because of safety standards through crash tests?
Just a guess but I was thinking the same thing.
Fat Mach
Nor Cal
2013 GT350
Even though "it happens", I am quite nervous of the preparation of the rest of the car if this would be the case. A factory is a controlled situation that absolutely should not have this issue this soon. I have had close to a hundred cars in my lifetime and I have never seen rust this soon to someone's or my car.
Something had to have happened either in the shipping or the factory if multiple vehicles are showing this "rust". Now if someone were posting this with a car that is 5 years + with surface rust, I would understand this is possible for normal wear and tear.
Having issues with this on cars 2 years or under is not acceptable and even if the warranty covers this, this does not bode well for the car or it's value. If word gets out that this is a problem along with the electrical issues, we won't be able to give these away in a couple of years.
At some point that steel was stamped. Prior to getting a coat of sealing primer, it started to rust. At least that is my opinion. I doubt the rest of the car would have the same condition.
Ford had Mustang hoods made of aluminum that had corrosion under the paint and it took them close to 10 years to get it straightened out.
Pioneer74
Dearborn
2022 Lightning Lariat ER - 2025 Mach-E Premium ER
Use Fluid Film. It's thicker and will last longer.
Pioneer74
Dearborn
F150 doors are aluminum and they pass crash tests. But aluminum is expensive. They probably used steel because it's cheaper.
Pioneer74
Dearborn
Mustang hoods had 2 problems. They weren't treated correctly before being painted and they had the squeeze-out problem I mentioned earlier. Paint doesn't stick to the adhesive as well as treated metal.
DennisD
Dennis
Omaha Nebraska
2022 Mustang Mach E
Once again, I can't stress this enough. The conditions in a Factory that build cars is totally in controlled settings. Ford (especially if they have had this problem in the past) should have known of all prior defects to assembly and painting a car and remedied them.
If your assessment is correct, then one can't assume that other things were not overlooked or cheapened to get these cars off to the consumer as fast as possible.
The quality control of Fords in general (as with most Domestic Brands) are far inferior to their counterparts in many instances. I had a Ford Focus and it may have quite possibly been the biggest piece of crap that I had owned. It is quite frustrating to see that Ford has not really changed their MO so to speak in producing "cheap" cars even when those cars aren't "cheap" to purchase.
Jonno21
Derby, UK
Mach-E AWD Long Range Space White
Let's see what Ford suggests to do.
I'll spary some sort of sealing in the drain holes anyway when I get it back after repair.
Just be careful not to block the drain holes with whatever you use as a sealer and poke out the holes with something pliable but non scratch, perhaps a cable tie? If anyone thinks of anything better than please suggest it. :) Pehaps we should all be clearing the drain holes anyway just in case. ?
Bobcat17
Gibsonia PA
2021 Mach E
I'm wondering if this might actually be part of the issue. Maybe it has something to do with being transported across the ocean? Something something salty sea water
But how would seawater get on the car while being transported? I would think it would be stowed in a dry compartment.
sockmeister
Pennsylvania
2023 Mach-E GTPE
SW Engineer
Not even 10.000 miles on it. It was delivered in August 2021. Job 1. Relativly mild continental climate over here. Rainy in the winter, not too much frost.
I do not seem to be the only one over here to have this. Not seen that after one year on any other car ever.
Do not have that on mine. If there's corrosion bubbling up under there, it's a defect. But it'll only be covered by warranty if it "perforates" the metal.
I'd be irritated. But in the state it's in right now, it's a very easy fix. Grind/sand it down and then just protect it with some black primer and paint. Since it's on the inside of the door, you can stop it without making a visible change.
Sorry that you're experiencing this... definitely a one-off defect or something different with drainage on the european models perhaps?
Ford Mustang Mach-E Rusty doors 1667398594943
MellowJohnny
Christian
YYZ
Solution Architect
Sure, but even in these "controlled settings", shit happens. Witness the windshield and glass roof recall - only affected a small number of cars before it was caught and remedied. Chalk that one up to human error. "Past performance is not indicative of future results" as they say in the mutual fund biz.
Given we have not seen, on this forum at least, a large number of East Coasters with MY21s complaining about the same issue leads me to think this is an anomaly. I hope :)
Quebec and Ontario essentially carpet bomb the roads with salt in the winter (Ontario uses 3 to 5 million tonnes per season, plus saline liquid) so if this was a big problem I'd assume it would have manifested itself by now in the "cold climate, east coast" Job 1 cars.
Again, every single post here is speculation, but it just doesn't seem like a pervasive issue.
I hope :)
21st Century Pony
Martin
Arlington, Virginia
...and Fusion aluminum hoods as well. Mine was one of the problematic ones.
BuckBaker
Buck
Durham, NC
2023 Mach-E GT Cyber Orange, '86 Bronco, '83 280zx
Accountant
Not claiming to know, I don't work, nor have I ever worked on a cargo ship. I do have a friend who works on a cargo ship and he sent me some pics of the cargo hold with a fog inside it from moisture in the air, so take that for what it's worth.
AlpaChino
JB
Indiana
2025 Kia EV9 Land
After reading this thread, I decided I should check over my own MME since I'm in the Midwest. I keep my baby garaged, clean and well maintained. I have 25k miles. I just noticed this below the rear passenger window trim.
Ford Mustang Mach-E Rusty doors 20221102_130128
This is the best picture I could get. Looks like the paint is bubbling. Is this covered in the bumper to bumper warranty?
