Seat won’t move back when turning car off
Kkbrit
Karen
Santa Rosa
Mach E
My seat suddenly stopped moving back when I turn the car off. Any suggestions on what to do to bring it back?
CompilerBreak
Seattle
2021 MME GT
I forget the name of the setting, entry assist maybe, but I'd double check it in the vehicle's menu, it's possible it reset after an update. If it is enabled, try toggling it off then on again.
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
It could also be that you have moved the seat back to it's furthest position. In which case it can't go any further
Mach1E
Check your profile. It probably defaulted to “guest.”
Only workaround is to change the settings is the guest profile as well to include easy exit.
Mine has been defaulting to guest at random times for over a year now. It comes and goes with no rationale.
Kkbrit
Kkbrit
Karen
Santa Rosa
Mach E
I have tried all this and it won’t reset.
Neil4Real
What have you tried? You've tried toggling "easy exit" off and on? Try restarting Sync, hold the volume down and next track buttons on the steering wheel until you see it turn off.
Then try again. Make sure your car is fully on when doing the above.
Ghost Ryder
LA
Tesla MYP, 22 GTPE
If all else fail, you can delete the profile and make a new one.
