Seeing increased charging rate after 80%
conviction
Santa clara
Mach e select
I used to see 6kw charging speed after 80%. In last few fast charges, I am seeing 20-32kw charging rate after 80%. Has Ford pushed faster charging speed update after 80% ?
Ford Mustang Mach-E Seeing increased charging rate after 80% 54849F48-9D9D-4B67-A32C-3FF21E45FDF5
Ford Mustang Mach-E Seeing increased charging rate after 80% A8D20F61-D905-4366-B536-663266CC7AEB
Ford Mustang Mach-E Seeing increased charging rate after 80% 27124E67-900D-4666-B24A-C57AC33D0014
hawkeye3point1
NH
Comes with the 2.1.0 OTA. But I believe its only available to Job 1 (early build cars) that have had CSP 21P22 installed by a dealer. Have you checked update status on FordPass or in the car??
breeves002
St. Louis, MO
2021 Mach-E GT PE
It comes with the CSP not the OTA. OTA is unrelated.
conviction
conviction
Santa clara
Mach e select
Started seeing this after my windshield recall service. So probably the dealer did it as part of recall.
breeves002
St. Louis, MO
2021 Mach-E GT PE
How to check this ?
Whats the build date on your car? On the door jamb. Or send me your VIN. I'm curious.
Has it been to the dealer recently?
How to check this ?
Have you had the car worked on? I had this CSP done when I had my 10K service. He was me charging today:
Ford Mustang Mach-E Seeing increased charging rate after 80% 3930FAC8-E97C-46AC-A819-0DEA327F79CC
45kW at 84% SOC.
Should be on the work order...
