Snow Removal
Gullwingdmc
Chip
Boston, MA
As we get closer to the dreaded winter season, I wanted to see what everyone’s recommendations were for removing snow and ice off the car?
I have an old brush/scrapper combo that needs to be retired, also a foam brush that works ok, but is a bit clunky for fine snow removal.
What does everyone prefer to limit scratches and reach the roof to clear all the snow off?
mdolan92869
Orange County, CA
Retired Software Engineer
I live in Southern California. No snow to worry about and rarely need to worry about rain, so just move here. Problem solved! :p
Stored in garage. Standard brush that extends. Key is to not pull ice off painted surfaces.
Gullwingdmc
Gullwingdmc
Chip
Boston, MA
I park in a garage, but I have to drive in blizzards regularly to abs from work. The extendable brush is something I’ve looked in to.
Tim_C
Mach-E FE GB
Gullwingdmc
Gullwingdmc
Chip
Boston, MA
connoisseurr
Connor
Northern VA
22 Rivian R1T, 23 Tesla MYP
IT Engineering
Thanks! I like the idea of the foam instead of a brush.
Well, the only problem I see with the foam is that it has a larger potential to trap large debris like bugs, road salt, etc. Be careful about scrubbing your car with that.
JamieGeek
Southeastern Michigan
spareelectrons.wordpress.com
Precondition to max temp; snow will melt right off.
Snow? Surely you jest! We get so little precipitation here. Drought, baby! ?
louibluey
FE "Louibluey" GB
I use a SNOW JOE, or some foam thing, like this one anyway, seems like some version of SNOW JOE usually goes on sale for around $10 every year. I also buy another one to replace the foam part on my very large telescoping yellow composite pole that I use to clear the solar panels (lots of vertical bolt ends tear it up pretty good every year, no matter how careful I am).
Definitely don't scrape close to the finished surface, just push / pull off the bulk, maybe leaving 1/8" to a 1/4" which will usually clear by itself, or if wet snow, it just slides off in bulk anyway.
Funny, speaking of winter, I just had my 225 Michelin X-ice SUV snow tires put on the 19" OEM rims today! But, I won't put them on MME yet, probably not for another month or so.
@SARANED
Edward
Omro, Wisconsin
Mach E CR1 AWD extended range Grabber Blue
Cover
BMT1071
Glendale, AZ
21 MME SR RWD, 23 MME GTPE
EV Technical Trainer
Well, up until last week... ?? The Colts and Niners didn't seem to be enjoying the 'atmospheric river'.
