DevSecNetAIOps, General PITA
It required FDRS in order to get the IPMA and PSSC software needed.
KAustin
WDC
Kia Telluride
My FE is in the shop getting the HV battery recall work done finally. I asked them to make sure all the software updates get done. I'll report back if anything happens. Haven't had anything since June. Yes, I'm in EA.
hack-e
Austin, TX
2022 Prem AWD ER MME
Robotics Engineer
For the record, I decided no to wait for the OTA updates for BC 1.3 and 10.1.1 and used FDRS for the first time over the weekend to update to all that. I really had hoped to get it all OTA. I'm going to mention my disappointment to Ford at the Cars & Coffee Event at Electrify Expo this coming weekend in Austin at COTA.
worachj
Eagan, Mn USA
2023 MME Select AWD Rapid Red Metallic (03/10/23)
My 2023 Select received 10.1.1 today.
Zardoz
WA
'22 GT
Glad to hear the update is still being rolled out and isn't on hold like so many updates have been. I will continue to wait impatiently.
Keytone
Victoria, BC
2023 MME P AWD Ex, Mazda3, Chevy Roadtrek 190
For 2 days I've noticed that I'm stuck on a Not Completed error:
Ford Mustang Mach-E Software Update 10.1.1 20241109_203957
ack154
2023 Mach-E GT PE
JUST got 10.1.1 today. Have had 10.1.0 for a while now. Not sure what took so long.
dallowev
DFW
2023.5 Ford Mach-E Premium EXR
My 2023.5 got it today as well.
Previous update was on 10/25.
The latest info I had is BC 1.3 for all existing models, including 2021, is very much in the works -- it's just going slowly
Are we talking normal human slow, Mach-e forum slow (3.336 microseconds), or geologic time scale slow? ;)
Chitown
Chicago, IL
2023 GT Performance
Software
In my experience, this means your 12v didn’t have enough charge. Drive it for something like 30 minutes. I believe 12v doesn’t charge unless the HV is charging or you are driving it.
And if you don’t have a GT avoid using 12v accessories while driving to charge the 12v as the non GT has a smaller transformer.
I believe when the SoC of the 12v is below 40% it also charges from the HV.
the problem is bigger software updates need more battery and so the threshold for the 12v SoC is higher.
