Speedometer Missing?
drg1012
Colorado
2022 MME Premium
Mechanical Engineer
To all those complaining about the speedometer being on the side instead of in the center-at least you have one :) My Mach-e decided to do this yesterday. Luckily everything back to normal after turning off and then back on...
Ford Mustang Mach-E Speedometer Missing? speedo
Looks like it got stuck on the battery% screen during boot-up. A Sync reset may or may not have also corrected that (a couple of members said a Sync reset did not fix it but a power cycle did). ??
Nathan R Jessep
2021 Mustang MachE4X; 2023 Mustang 5.0 GT 6 speed manual
Attorney
Same thing happened to me a couple of weeks ago. I didn't notice until I was getting on the highway, where I always check my speed because the local State Patrol loves to sit in a specific cross over. Didn't get back to normal until I shut it off and restarted it (seems to be the way to fix most of the simpler annoying problems I've encountered....cause in reality we are driving a 4 wheel driver "computer". LOL)
RedAero42
Tempe, AZ, United States
Mach E ER AWD, Star White
Hi all... just chiming in on this thread to say we have experienced this multiple times over the last couple months. If it happens again I think we'll start "reporting" it somehow...
Mrs Chivus
Richmond, VA
2021 Ford Mustang Mach-E
This same thing just happened to me! Last Friday I was taking my husband in for surgery. Granted, we were driving MUCH earlier than either my car or me is usually even awake. But I was awake enough to notice that I had no speedometer! I was thankful that I did not have to drive on the highway. And I've had no updates to my 2021 Mach-E since June 2024.
Ford Mustang Mach-E Speedometer Missing? IMG_2221
PaulSW
Paul
Colorado
2022 Select AWD ordered 3/11/22
I had this happen today for the first time on my 2022. Is there any way to report this issue to Ford?
There’s a “provide feedback” function in settings where you can record a message.
TheLongRanger
Victoria BC
2023 Mach-E Premium AWD
This had been going on from about the 3rd month I had my 2023 Premium AWD X. Several trips to two dealerships and no change. Finally they changed my entire charge port. They said that it was miscommunicating with the main computer or it had been assimilated by The Borg or something. Anyway, hasn't happened since.
Ford Mustang Mach-E Speedometer Missing? 1000046484105
MacherAWD
North Shore MA
Healthcare Software
That usually means you weren't stepping on the brake (or hard enough) when you turned it on and it is in accessory mode.
TheLongRanger
Victoria BC
This happened about 20 times in about 8 months and then never again after charge port. Surprisingly my feet still hit the brake pedal. :crackup:
